Question about BT Lands Phones
My BT landline has shown check connection for several hours there does not appear to be a problem at my home and my BT internet is working fine is there a problem in my area BB10?
  • 556 Answers
SOURCE: Internet connection keeps dropping
Two possible reasons
If you have hidden your network name (SSID) in the wireless configuration in the router and use WEP or WPA security there may be a bug that can result in extended disconnect periods. Recommended solution unhide the SSID and keep the WEP or WPA security.
Second there are numerous wireless devices in use. Keep your wireless phone base station away from your wireless router. Try changing the channel your router's radio uses to transmit -- Channels 1, 6 and 11 are preferred. Try one you are not using, if that does not work try the other. (If you can see the surrounding channels in you connection wizard you may want to start with one no one else is using)
Posted on Jan 02, 2008
szfeco
SOURCE: Router works at computer store, but not at my home
Try to reset the TCP/IP stack and the Winsock by the following way:
In the Start menu -> Run enter cmd.exe (press OK or hit Enter)
In the black command prompt enter the following commands:
netsh int ip reset reset.log
netsh winsock reset catalog
Hope this helps.
//Feri
Posted on Mar 18, 2009
  • 6 Answers
SOURCE: wont connect ti internet
Same device as mine. and im on home hub aswell. Uninstall the drivers. Restart windows. Reinstall the drivers. Hopefully this should make a differance. Also when reinstalling. make sure the device is not plugged in until you finish installing drivers. And maybe put it into another usb when you are ready to try again. this is something good to try on older systems. or OS's.
Posted on Jun 12, 2009
toolman3
  • 39 Answers
SOURCE: Just installed a D-Link DFE 530TX network adadpter
Sounds like an IP address problem. Your IP address on both the NIC card (DFE 530) and the router have to be in the same address range. You can do this 2 ways. 1... Have your router hand out addresses automatically. Make sure DHCP is enabled and that you have at least one address available for it to give out. ie. 192.168.0.2 through 192.168.0.3. The first three number must be the same as the router. The other option is to manually set your IP address on your nic card to match the router. If the router is lets say 192.168.0.1 then you can assign 192.23.34.2 to your computer NIC. If you haven't been able to access your router then check your router manual to find out the default IP address and use the same number for your NIC changing only the last number. The largest number you can use is 255. Hope this helps.
Posted on Jul 12, 2009
Geekman
  • 32281 Answers
SOURCE: HP pavilion network adapter not found
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model computer and the XP Windows version of the drivers you require and install them. Use this link to download the drivers :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Posted on Aug 03, 2009
Whom to contact for landline connection?
There are numerous different telephone providers. You'd want to go to each of their websites and check there. Here are some of the larger names:
AT&T Traditional Landline Phone Service
https://www.att.com/home-phone/landline.html
AT&T Wireless Home Phone
https://www.att.com/cellphones/att/att-wireless-home-phone.html#sku=sku7250257
Verizon Fios Digital Voice
https://www.verizon.com/home/phone/fiosdigitalvoice/
XFINITY Voice
https://www.xfinity.com/learn/home-phone-services
Frontier Home Phone Service
https://frontier.com/shop/phone
CenturyLink Home Phone
http://www.centurylink.com/home/phone/
There are also probably numerous local phone companies you can contact. Try using this Google search for "home phone providers near me"
https://www.google.com/search?q=Home+phone+providers+near+me
Apr 11, 2017 | Contact Computers & Internet
Have purchased this producct plugged it in no ringtone no flashing to indicate incoming call have operational line with dialing tone, help please asap as only line into work
I am assuming that you can hear dial tone on the handset, and you can make calls on the phone. If this is correct, then I would recommend contacting BT and getting the phone replaced with one that works. http://www.bt.com/help/home/landline.html
Apr 16, 2015 | BT Duet 210 Corded Telephone - White
How do I return a set of BT phones purchased in February 2014 which have developed a fault
According to BT's website, simply calling 150 (assuming you have a BT landline) will get you through to someone who will be able to sort this out for you.
How do return telephone bought on BT com Help BT com Help
If you do not have a BT landline you can call them on:
  • From a landline: 0800 800 150
  • From a mobile: 0330 1234 150*
  • From abroad: +44 179 359 6931**
Nov 27, 2014 | BT Lands Phones
Can't connect to server to get my btinternet mail
bet you can! I'm not a bt customer and I was able to get on their site to try and understand all these SAME questions about getting bt email. You're probably even on their server when you get onto the Internet, since it appears BT is an ISP (Internet Service Provider). You can go to http://home.bt.com and read how to resolve your issue, or talk to their agents and get sepcific help.
Jul 07, 2014 | iPhone Apps
Caller display doesn't work
From the BT website...
"If you are using your phone on a broadband line make sure you fit an ADSL microfilter between the telephone line cord and the telephone socket."
I'm guessing you have one on the landline, probably next to the router but not the handset base :-)
Why is my Caller Display not working Help BT com Help
Apr 23, 2014 | Lands Phones
I have Epson SX600FW and am trying to set up the Fax capabilities plus have a phone attached to the printer. I connected the printer\fax Line to the BT socket and the phone to the EXT socket but got no...
https://www.epson.co.uk/support?productID=2933#manuals
Download Fax Guide.
Note instructions for DSL phone line is different than regular phone line. The fax manual there has pictures of how that is done.
If BT is faulty, they offer support:
From the UK: 0800 800 150*From outside the UK: +44 179 359 6931*
Our repair teams are open:
7 days a week, 24 hours a day
* The cost of the call depends on the country and network you're calling from.
http://www.bt.com/help/home/contactus/#/landline/fix-landline-problems
Feb 06, 2018 | Epson Stylus Multifunction Printer/...
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
Nov 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Lands Phones Logo
Top BT Lands Phones Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a BT Lands Phone Expert? Answer questions, earn points and help others
