Question about Electrical Supplies
I have a megaforce generator 6500, wanting to know does it have a fuse and where is it
    Sergeant:
    Habit-Forming:
  • Electrical S... Expert
  • 170 Answers
What exactly is the problem? No 12v or mains electricity?
Posted on Dec 08, 2016
Northstar 6500 generator oil pressure switch wiring
Need to look at what your talking about, too many possibilities.
Jan 18, 2013 | Northstar Generator 10 Hp, 6500 Watt,...
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
Aug 13, 2012 | Onan Cummins RV QG 6500 Generator, 6500W,...
Need battery for Onan 6500 Generator
I have searched but cannot actually find what type male of battery it uses, other than it is a Lead Acid Battery. Now with lead Acid batteries, it is the actual Capacity, in Both Amperage output, and Physical capacity. So based upon that ANY 12 V DC Wet Cell battery of the SAME Physical size, and CURRENT capacity will work. Look on the actual battery itself, it WILL/Should have identifying marks written on it. Get one the same, it is NOT all that critical.
May 23, 2010 | Watts Onan Portable Generator - 5000 ,...
I have no power output from a MegaForce 6500 Generator. I get a reading of 5 volts when checking the positive lead to ground. I have read that the generator may need to be flashed and looking to find out...
Don't bother, just get a battery and repolarize your capacitor. Tap the pos to pos and neg to neg for a second or 2 them reattach the leads and see if it starts making power. A 9 to 12 volt battery will work ok for this.
If it wont take the charge, just get a new cap. The original capacitors are pretty cheap anyway.
Mar 07, 2010 | Electrical Supplies
I have a 6500 es that keeps blowing the 15 amp fuses. It will sometimes run 1 hour or maybe even 2, but then it blows the fuses. What could be the problem.
What are you pluging into the generator??? If the the item/s are drawing more amps or watts, than the 6500 will handel, EX: 6500+or++ or if you add something while it is running, ka pow! Please let me know specifically what you have pluged into it, the fuse only blows if you are overloading it! Check the amp or watt draw of what you are pluging into it to see if the generator can handle it. If you overload the generator enought times you can burn the windings and than it gets costly. Talk to your local shop about what it can handle.
Jul 18, 2009 | Honda Electrical Supplies
Lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Jun 05, 2009 | Watts Onan Portable Generator - 5000 ,...
Onan 6500 male 120/240 plug
Northern Tool has a hundred plugs/recepticles. you need to know the amps and volts. just match them to the pictures. or email them a pic of what you need. they helped 3 of my customers with the issue. hope that helps...good luck...
May 28, 2009 | Watts Onan Portable Generator - 5000 ,...
Electrical Supplies Logo
18 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
