Question about Furniture
KOOLATRON WINE FRIDGE Model WC29, compressor is getting noisy, what can I do?
fanny
  • 146 Answers
SOURCE: Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Posted on Nov 04, 2007
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Posted on Apr 13, 2009
  • 205 Answers
SOURCE: our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Posted on Oct 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: i have a koolatron coca cola fridge/cooler model
Here is the AC Power adapter: (Part number is AC-15)
http://www.cooler-store.com/koolatron_ac15_adapter_369_prd1.htm?pSearchQueryId=82308
The power cord may have a fuse installed in the plug. If required replace the fuse with one of the same
amp rating (A) only.
More sources for the adapter:
http://www.google.com/products/catalog?q=AC-15+cooler+power+supply&rls=com.microsoft:en-ph&oe=UTF-8&startIndex=&startPage=1&um=1&hl=en&ie=UTF-8&tbm=shop&cid=8110029372488433647#
Hee is the DC only cord:
http://www.toolfetch.com/Category/Commercial_Trucking/Thermoses_Jugs_Coolers_Cups/Replacement_Parts/DAS-70102.htm
WARRANTY AND SERVICE PROCEDURE
If you have a problem with your THERMOELECTRIC
WARMER/COOLER, or require replacement parts,
please telephone the following number for assistance:
North America 1-800-265-8456
Thanks for choosing FixYa,
Kelly
Posted on Aug 22, 2011
  • 91 Answers
SOURCE: I purchase a koolatron CVF18 Vending Fridge I plug it in and neither the fan nor compressor came on but the power light on the power cord came on
Sounds like the timmer has not passed the defrost cycle, if you look near the compressor unit, you will see a box with wires going into it from compressor and up into the unit, you should see a small dial about 10-15mm diam, turn this dial clockwise, may need a screw driver, should work once turned, If you cant locate it near the compressor, have a look within the unit or ontop for the timer unit with the dial and tun it clockwise, if the unit operates, spray with a good quality lub spray and turn it fully for 5 revs. Should work fine once done....Russ
Posted on Aug 12, 2012
Compressor in our wine fridge is getting pretty noisy, what do I need to do?
If you mean the motor for the fan because a condenser is just a type of radiator. So the condenser fan motor must be the noise if you are sure the refrigerant pump is not the noise..
Dec 07, 2016 | Optics
My Koolatron Wine Cooler, model WC08 will not turn on. Any ideas what I should check first? I checked the outlet. It is fine.
There has to be an internal breaker that went off or fuse. You may have to remove it from the casing to get to it.
Jun 26, 2016 | Koolatron WC08 8-Bottle Countertop Wine...
My Koolatron WC12-35D wine cooler just stopped working. No lights come on at all. Replaced a capacitor that was bloated and leaky, but still no change. Everything completely dead. Any thoughts?
have a technician check out the compressor
see if there is a red overload button nearby on the fridge a sit there is it may have popped when the capacitor blew out
Oct 24, 2015 | Furniture
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
My wine cellar doesn't cool
Since november2014 I'd tried having my koolatron 18 bottles cellar repair . no parts aviable no koolatron assistance and when i'd phone no answer. that' s SCRAP ...
May 12, 2014 | Koolatron 18 Bottle Dual Zone Wine Cooler
Why are wine coolers so noisy?
Compressor-run wine coolers may be slightly noisy at times; however thermoelectric coolers are completely silent.
Jul 31, 2012 | Furniture
Plugged it into 240V now it wont run
there is a little relay on the compressor more then likely that is toast. I would start by pulling it off and replacing that. Get back with me and we could go from there. The relay protects the compressor from overloading. Now do you have a fan beside the compressor?
Feb 07, 2009 | Koolatron Coca-Cola Personal Fridge - KWC4
Vending machine issues
Only the fan at the compressor turns on and off with the compressor cycle. The evaporator fan runs steady to maintain air circulation and temperature balance and to affect evaporator defrost in the off cycle. Sometimes the condenser fan will run continuously to assist in the evaporation of condensed moisture from the evaporator drainage.
May 30, 2008 | Koolatron (785169015699)
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Furniture Logo
167 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
