Question about Building Materials
Having problems programing my new remote for an existing door opener. Tryed unplugging it and nothing works, what to do.
    Novelist:
  • 112 Answers
Rick, if you just bought the remote new, be sure you have a compatible one with the old opener. These are tricky because some lookalikes aren't interchangeable. Did you refer to the programming directions for your unit? The color of the program button on the opener unit is a good way to identify the correct remote frequency and thus the correct remote. Also, were you having trouble with the old remote? Then maybe you problem is not the new remote at all. Which remote did you buy and what is the make of your opener and what color is the program button on it?
Posted on Dec 07, 2016
Can a garage door opener be reprogrammed so existing hand held remotes no longer work and new ones programmed to open garage door?
take the battery out of the old one and discard
with the new one
press the program button in the board then press a button on the new remote and allow the door to cycle up and down
the new remote is then programmed
one press to open and when finished , one press to close
Dec 24, 2017 | Building Materials
AEG lavamat 705500 - Door wont open even after the program is totally finished. What to do? Is there an emergency opening?
unplug it take the top off the scews should be in the back then reach down inside the washer by the door lock and find a pull release hope this help every model in the usa has this but i am not familiar with your brand
Jan 01, 2017 | Washing Machines
We have a Liftmaster garage door opener. I bought a new remote control for it - a Liftmaster security plus. I have tried to program it by pressing the button on the garage door opener, then pressing the...
YOU NEED TO MAKE SURE YOUR REMOTE IS THE SAME FREQUENCY AS THE EXISTING UNITS.
IF YOU LOOK ON THE BACK OF THE REMOTE THERE SHOULD BE A FREQ# IF THEY ARE NOT THE SAME YOU NEED TO EXCHANGE THE REMOTE.
HOPE THIS HELPS
Mar 26, 2011 | liftmaster Chamberlain Garage Door Opener...
How do you get both remotes programed at the same time for our sears garage door opener?
If the problem you are having is if you program one remote the other will not work. If this is the case one of your remotes has reverted to billion code technology. The only fix for this is to purchase a new remote and eliminate the problem remote. You will find the new remote will work with one of your remotes but not the other one. You should remove the battery from the bad one and trash it.
Jul 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftman 1/2 garage door. Model 13953879. RF intereference issue
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Apr 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
My remote will open the overhead door when I am standing inside garage, but not from outside
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door will not open if i am standing 3or4 feet from door
Nov 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keyless entry
watch this video if the video dosent work go to www.vehix411.com to see the video " />
Dec 03, 2008 | 2000 Chevrolet Venture
Building Materials Logo
69 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
