Question about The Music
Looking for user manual for organ The Conn Delux Caprice Model No. 478231 or 478241
Can't find where to oil my conn threaterette organ
I do not beleive you normally oil a Conn organ, only tonewheel Hammonds require oiling.
Mar 22, 2018 | Conn Music
What makes it hum loud? Conn organ 71450
Could be failing power supply
Mar 26, 2017 | Conn Music
I need to look at a service manual for a conn 643 organ
Did you find one? I'm looking for one, and an owner's manual.
Feb 17, 2014 | Music
I purchased a used Hammond Organ Aurora, Model 700, 710 C125 but the previous owner did not have the manual for it. I am looking for a manual so I know how and what to do to play it. I don't know what...
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
Nov 23, 2010 | Music
Music Logo
22 people viewed this question
Top The Music Experts
Larry Stiles
Larry Stiles
D. E. Hev
gbob59
Are you a The Music Expert? Answer questions, earn points and help others
