Question about Westinghouse Televison & Video
How do I connect my sons xbox one to his westinghouse tv? It only has one input for HDMI and it's not working for his xbox
    Top Expert:
  • Westinghouse Master
  • 78,010 Answers
Do You have the video input selection source made for the HDMI? you must turn on the HDMI input.
Posted on Dec 07, 2016
Original xbox system
How do you have your Xbox connected to your TV? Through an HDMI cable? Are any other components involved, such as a Home Theater system, etc? If you have your Xbox going directly into your TV, you should be able to select the input (IE: HDMI 2) on the TV, then power on your Xbox and be ready to go.
I hope this helps!
Oct 26, 2013 | Insignia Televison & Video
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
WestingHouse HDMI port wont work with PC but will for xbox 360?
You should never try to connect any cables when the devices are on. Always try to connect inputs or outputs after switching the devices off manually. Looks like the input port has gone bad. Try switching off the monitor, removing the plug and leaving it for 48 hours and retry. If you notice problems still, it is better to refer it to a qualified service technician.
Jul 19, 2012 | Westinghouse SK-19H210S Television
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
I bought a Westinghouse 26" Widescreen LCD tv less than a year ago and we are having troubles with the HDMI 1 channel. My son has his XBox 360 hooked up through this channel and it will randomly go blank...
I would recommend to call the Westinghouse customer service since you are at least close to the year warranty, their number is 1800-701-0680, other than that the only thing you can do is to do a factory reset by going in to the menu, go under the settings tab, and it will be the last option.
Nov 15, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
Hdmi - out of range
If your hdmi cord is good, and you are going from xbox to tv via hdmi , make sure you have your input on input 1. Hdmi ports are usually by default set to work in the first input of any tv or monitor.
Apr 12, 2009 | Televison & Video
No input signal for HDMI 2
I reset the HDMI function by pressing the POWER button on the tv and holding it in for several minutes. After turning the tv back on, everything worked fine.
Feb 05, 2009 | Westinghouse Televison & Video
Connecting my wii to my home theater
  1. Connect your set-top box HDMI output to the Xbox One HDMI input.
  2. Connect the Xbox One HDMI output to your A/V HDMI input.
  3. Connect your A/V HDMI output to the HDMI input on your TV.
  4. Notes
  5. This option requires that all devices support audio over HDMI.
  6. Surround sound from your set-top box will not be passed through the Xbox One.
  7. When you perform this kind of basic setup with an A/V receiver, you're passing both audio and video through another device. Depending on your equipment, there's a small risk of audio or video lag.
  8. Connect your set-top box HDMI output to the Xbox One HDMI input.
  9. Connect the Xbox One HDMI output to the HDMI input on your TV.
  10. Connect the audio output from the TV to the audio input on the sound bar using either HDMI or optical S/PDIF cables.
Nov 09, 2017 | Electronics - Others
Xbox 360
There are a couple of options you can use.
Are your DVD and cable actually going to the Onkyo first and then to the TV? I am assuming it is, if you listen to the Onkyo when watching a DVD or cable.
The Onkyo receiver you have has 2 hdmi inputs and 1 hdmi output.
Does your Xbox360 have an hdmi output and that is what you want to connect to the Onkyo? Some do and some don't.
If your Xbox has a hdmi output and you are already using the 2 hdmi inputs on the Onkyo, you can not connect the Xbox using the hdmi, you have no more hdmi to connect to, so you must go thru one of the other inputs of the Onkyo.
The hdmi has the video and audio together, the other video options do not. you would need to run seperate audio cables as well.
Your Xbox should have a composite video (yellow RCA jack) output or a component video (1 red, 1 blue, 1 green RCA jack) output.
When you connect the Xbox thru, lets say the composite video of the Onkyo , you will also need to connect the audio from the Xbox to the Onkyo on the same input. It should be right next to the yellow RCA jack or right under it. They are 2 RCA jacks, one red and one white.
You will then need to connect the composite output of the Onkyo to the composite input of the TV.
When connecting like this, you will also need to select the composite input on your TV with your remote for your TV. Your TV should have an input button that lets you go thru all the different inputs to it.
you can also use the component video from the Xbox if it has that. But you must also run the audio to the Onkyo as well to the corresponding audio inputs of the component video input on the Onkyo.
This may sound a little confusing, but remember that the hdmi has the audio and video in one cable, the other video options do not, so you must run additional cables for the audio to the Onkyo from the Xbox.
Also remember whichever video you use from the Xbox to the Onkyo, you must also run that same video from the Onkyo to the TV and then switch the TV over to that input when you want to watch the Xbox on the TV
Jun 21, 2008 | Onkyo TX-SR605 Receiver
Televison & Video Logo
29 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
