Recently hooked up to Mac mini System and now I get D Source Locked No Signal on my screen what can I do to fix this it was working fine
2 Suggested Answers
cjackHD
  • 71 Answers
SOURCE: Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
Posted on May 31, 2009
The front driver signal doesn't work.
Sounds light a bad light socket . Can you remove the bulb you replaced and test it with an ohmmeter or hook it up to a power source to see if it in fact is good
May 06, 2015 | Cars & Trucks
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
The monitor is black with a error message :input signal out of range We are connected to a Mac Mini This problem seemed to happen after the monitor was accidently disconnected and then when it was...
Can you please get me the make and model of the monitor? Also did you check to see if the refresh rate of the monitor matches with that of the mac mini?
Nov 21, 2010 | Hannspree Computers & Internet
No video signal.
Hooked up how to what model of TV? Try a different video source or video input on the TV.
Mar 20, 2010 | Koss KS3102 System
IOGear (GCS632U) 2-port KVM Switch problem. All functions well it seems after connecting for first time Mac Mini and XP Windows Dell PC except when switching to Mac I get a blank dark screen. Another side...
The IOGEAR GCS632U is designed to work with VGA computers and monitors. Using the Mini DVI to VGA adapter is not guaranteed to work with this KVM switch.
The Mini DVI to VGA adapter can only convert the port, but it does not have an ability to convert the signal from digital to analog when it's connected to the KVM switch.
What you need to have is a DVI to VGA SIGNAL converter. Unfortunately, I don't have a model number handy, so I would suggest to contact IOGEAR, because I'm sure that they already have a work around with this issue.
Thank you and good luck!
Oct 11, 2009 | IOGear GCS632U 2-port KVM Switch
Mac mini display problem
Sounds like your monitor is not set right. Is the monitor LCD or CRT type? You can open system preferences from the top of the screen under the apple icon. Try and see if you can adjust the resolution settings. Also if you have an LCD screen set to "auto" adjust to reset the screen. Good Luck.
Aug 03, 2009 | Apple MB464LL/A Mac mini Desktop
Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
Jul 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
I am trying to re-connect a Mac Mini DVI output to an old (original model) Gateway42" plasma TELEVISION. The problem is I re-set the display on the Mac Mini to a widescreen resolution, which the TV will...
Unplug both from power , and remove mac battery, restart first mac then TV, already connected.
Check source with tv remote, and ensure mac res is correct.
Mar 28, 2009 | Televison & Video
Hooking up a Mac to tv
I ran into the same problem with my "50 maxent. The manual clearly states that mac resolutions are not supported. We won't let that stop us. Step one is to download switchresx. It's a simple utility that should allow you to define custom resolutions. http://www.madrau.com/ .
Step 2 is to download chicken of the VNC. http://www.macupdate.com/info.php/id/9517 . Once this is installed on a separate mac from the one you are trying to connect to the maxent take your mini and hook it up to the RGB port on the maxent and boot it up. Once this is done use chicken of the vnc to take control of of the mini with the other mac. Now you can change the resolution on the mini using switchresx which you installed on the mini earlier. In the case of the maxent you will need to set it to 1366x768 at 60 hz. If using another flat panel consult your user manual for the correct resolution. In my opinion there is no flat paned tv this should not work for.
Sep 30, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
