Question about The Computers & Internet
This rectangular prism is made from centimeter cubes.What are the dimensions of the prism width x length x heightWhat are the dimensions of the prism width x length x height
  • Geoff White
    Geoff White Dec 11, 2016
    We cannot say, as you have not given enough information. Probably you were going to say how many cubes total, and possibly one other piece of info.
SOURCE: i need the following info
Exterior Dimensions
Wheelbase
2519 mm
Front Track
1527 mm
Rear Track
1503 mm
Overall length
4159 mm
Overall Width
1763 mm
Height (unloaded)
1415 mm
Ground clearance
n
Unladen weight in kg / gross weight limit in kg
1375 kg / 1935 kg
Posted on Nov 05, 2008
  • 10865 Answers
SOURCE: 1998 acura cl 3.0l battery dimensions? height,
Hello. 12 V, 720 cranking amps at 0 degrees F, 910 cranking amps at 32 degrees F, 9-5/16 x 6-13/16 x 7-5/8 in. tall, 31.7 lbs., Joe
4 thumbs up please. ty
Posted on Oct 27, 2010
  • 3247 Answers
SOURCE: I need the length, width height dimensions for a
if you cannot view this picture then go to kitchenaid site and type model number kuds02frss and select installation guide from the list. Please rate this solution if helpful or else post a comment.
Posted on Feb 25, 2011
rockmeister
  • 2047 Answers
SOURCE: Dimensions of a Pontec SP-70G
the Pontec submersible fountain pump SP-70G is a wonderful unit. It is durable as well as convenient for use. Here are the dimensions 2.43" L x 1.79" W x 3.31" H. Weight is 1.5 lb.
Hope this solution has been helpful?
Posted on Jun 17, 2011
Donateli
  • 74 Answers
SOURCE: surface area of a rectangular prism whose length
Since the 'base' and 'top' of any prism have the same shape, the surface area can be found by
  • surface area of prism = 2 * area of base + perimeter of base * H
So for the rectangular prism in your example..
  • surface area = 2LW + 2(L+W)H
  • = 2 * 7 * 4 + 2*(7+4)*5
  • = 56 + 2 * 11 * 5
  • = 56 +110
  • = 166 sq cm
Hope this helps
Posted on Sep 14, 2011
Rectangular prism is made from centimeter cubes. What are the dimensions of the prism width x length x height? What is the surface area of the prism? What is the volume of the prism?
Dimension of the prism is the number of cubes in width x length x height.
Surface area is 2(w x l) + 2(l x h) + 2 (wxh)
Volume is the number of cubes.
Good luck,
Paul
Dec 07, 2016 | Office Equipment & Supplies
Abby builds the first layer of a rectangular prism using 6 cubes. Liam adds 2 more layers. How many cubes are used for the prism?
Base=6
2nd layer=6
3rd layer=6
total is 18
A rectangular prism is a solid (3-dimensional) object which has six faces that are rectangles. It has the same cross-section along a length, which makes it a prism.
Mar 02, 2015 | The Learning Company Achieve! Math &...
Volume of rectangle formula
A rectangle is a two-dimensional figure and doesn't have a volume. It has an area equal to length times width. A rectangular prism has a volume equal to length times width times height.
Feb 06, 2014 | Office Equipment & Supplies
Volume of rectangular prism
Volume =(Area of base)*Height.
Since it is rectangular prism, the base has the shape of a rectangle (Length L, Width W). Its area is L*W
Conclusion: Volume of a right rectangular prism with dimensions L, W, H, is L*W*H
Dec 18, 2013 | Computers & Internet
The volume of a rectangular prism is 2,058 cubic cm. The length of the prism is 3 times the width. The height is twice the width. Find the length of the prism
Right Rectangular prism, Length L, width W, Height H
Volume=2058 cm^3=L*W*H
However
L=3W, and H=2W
(3W)*W*(2W)=6 W^3=2058
W^3=(2058/6)=343
W=Cube root of 343=(343)^(1/3)=7 cm
L=3*7=21 cm
H=2*7=14 cm
Oct 29, 2013 | Computers & Internet
What is the volume of 4in,9in,6in
Assumning that you have a rectangular based prism, you get the volume by multiplying the three dimensions (Volume =length*width*height). In this case Volume= 4*9*6=216 cubic inches
Mar 05, 2013 | Computers & Internet
Is time three dimentional or four dimentional?
Because of Einstein, we often call time the fourth dimension. Special relativity shows that time behaves surprisingly like the three spatial dimensions. The Lorenz equations show this. Length contracts as speed increases. Time expands as speed increases.
Scientists have been graphing time, as if it were a length, for hundreds of years. To the left is a typical graph, showing two things in motion at the same speed, one to the left and one to the right. Time never behaves exactly like a spatial dimension. You cannot go backward in time. And you normally cannot go forward at different rates. But, there are surprising parallels. For some purposes, it is handy to call time a fourth dimension. For other purposes, it is not.
Pretend, for a moment, that there are more than three spatial dimensions. What is a four or five-dimensional cube like? It is hard to visualize. But, we can make a few deductions about such an object. What if a 5-dimensional cube is 2 centimeters on a side, what is its 5-dimensional volume? Well, we can easily generalize from the first three dimensions. A 2x2 square is 4 (2x2) square centimeters in area. A 2x2x2 cube is 8 (2x2x2) cubic centimeters in volume. A 2x2x2x2x2 5-dimensional cube is 32 centimeters-to-the-5th-power in 5-dimensional volume. None of that can be visualized. But, it makes sense. What is the distance between two points in 5-space? You can easily deduce a 5-dimensional Pythagorean Theorem.
A science fiction story says that time is the fourth dimension, and space is the fifth. Space is the first three dimensions
Sep 17, 2011 | Computers & Internet
Surface area of a rectangular prism whose length is 7 cm.,width is 4 cm., and thickness is 5 cm.?
  • = 56 + 2 * 11 * 5
  • = 56 +110
  • = 166 sq cm
Hope this helps
Sep 05, 2011 | Encore Math Advantage Algebra II and...
What is rectangular prism?
Hello
Rectangular Prism/Cuboid Definition:
A Rectangular Prism/Cuboid is a solid figure bounded by six rectangular faces, a rectangular box. All angles are right angles, and opposite faces of a cuboid are equal. It is also a right rectangular prism.
Rectangular Prism/Cuboid Formula:
Area of Base(A) = l * w
Perimeter of Base(P) = 2l + 2w
Surface Area of Prism = 2(lw) + (2l + 2w)h = 2A + Ph
Volume of Prism = lwh = Ah
Diagonal of Prism = Sqrt(l² + w² + h²)
where
l = length, w = width, h = height
Hope this helps, if so do rate the solution
Jan 15, 2011 | MathRescue Word Problems Of Algebra Lite
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
