Question about Dishwashers
We have a Fisher & Paykel DD24 drawer dishwasher. It has a U-6 code. We have checked the water pressure that's fine. Checked the spray arm. Does it sit on the impeller, is there a mounting valve?
4 Suggested Answers
SOURCE: water not going through spray arms
Have same problem except big motor spins independent of stripped? impeller. tried to reassemble but seems mechanical or adhesive agent misssing from one shaft or the other and the motor spins the impeller (now tight) only to have it slip off again and stop pumping water.
Posted on Feb 04, 2008
Master_Tech
  • 770 Answers
SOURCE: fisher paykel
Check your email
Posted on Jul 09, 2008
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
U6 Error code on dish drawer
It might be helpful if you provide the model number of your dishwasher. It is likely the dishwasher has been set at a water pressure setting different to your mains pressure. If you are in normal water pressure area the selection is HI otherwise LO. Depending on the model the setup information is different.
Jan 26, 2013 | Fisher and Paykel Dishwashers
Machine Running noisy during cycle
lift off spray arm and remove motor rotor and remove any debri this can cause a noisey motor.
Sep 04, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and paykel m# dd 6031 bottom drawer will not fill just makes noise when I try to run it please help
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
To replace check this link:
http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Oct 18, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
We have a double draw dishwasher and both are leaking water although we have only ever used the top one. We have cleaned it with Finish dishwasher cleaner and I have also checked the pipes are not blocked...
I need more information at to the problem, when the drawer fills with water and starts to run, are there suds? Which drawer has the issue? How much water enters each drawer? Should fill just under spray arm at the bottom (0.7 gal). Can you tell if the lids are sealing the drawer? Are you getting a fault code of continuos beeping noises from both drawers? Which model do you have?
I would like to help you but need more information to direct you in the correct repair of your unit.
Aug 28, 2011 | Fisher and Paykel Dishwashers
U3 error code
I believe U3 error on your model of dishwasher could also mean a couple of other things like either the drain hose has an obstruction (kink) or the inlet water pressure is not correct.
Hope this helps in finding out what could be the actual reason. T
o find the kink if any, pull the drawer out as much as possible and feel the hose. Might be better if you took the bottom drawer out from the casing and inspect the hose completely. As the problem is limited to upper drawer you do not have to worry about what is under the bottom drawer. Check the water pressure setting is same for both drawers. If so then that is not an issue as bottom drawer is working ok according to your description. See your manual for instruction on how to check the water supply pressure setting on your dishwasher.
Jun 13, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
I have a Fisher/Paykel dual drawer dishwasher and the top drawer now makes a loud grinding noise - appears to be coming from the front of the unit. Any thoughts? Any home-based solutions?
Remove dish rack, spray arm, remove filters, remove the rotor (under the spray arm) Check if the rotor itself is making any sound or not rotating freely when you turn the impeller on the top. Replace if needed, otherwise - carefully check for debris.
Nov 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel dishwasher:
Turn off dishwasher's circt braker at distribution panel (usaly located in garage or in basement)
1. Open lower drawer
2. Push in two plastic buttons at front lower corners.
3. Remove drawer from railing
4. Remove water from bottom of dishwasher
5. Use hair drier to dry off bottom copartment, specialy in left corner at floding switch location.
6. Install drawer on the rail in position when plastic buttons pup up
Mar 27, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Model 601V2 dishdraw showing U3 error message
I have had my Fisher Paykel dishdrawer for 8 years and it has never completely worked. I would get a U3 code on the top drawer intermittently. I have had my drains rerouted twice, LP - HP reset, service men replace the back flow flap and mother boards without luck... until I was able to get my hands on the service manual. Turns out the solution is quite easy. If you have a problem with the U3 code it means the drawer is not draining appropriately, The washer only gives a preprogrammed 60 sec to drain the drawer. So if your drawer is overfilled, it will think it has a drain problem. The following is taken from the service manual...
"U3 - Time to fill was too short, indicating water was still in the tub.
Possible Causes:
· Drain pump is blocked.
· Drain hose is blocked.
· Sprayarm or rotor not turning
freely.
· Motor electronics have failed.
· Machine set to 'LP' on a high
pressure water supply.
The tub fills with approximately 2.2 litres of water, level with the base of the spray arm attachment. Once this level is reached, the wash pump (which has sensed the fill at 30 second intervals during the fill), becomes primed and pumps the water through the spray arm which will then rotate.
The water level is monitored by sensing the motor load through the electronics."
The solution is to turn your water supply valve part of the way on to limit the gpm flow to the drawer. This way, the drawer will not have over-filled in the 30 sec it took to sense the motor load. I have tried it and wow no more U3. Hope it makes sense and hope it works for you.
jim
Jul 13, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
