Question about Air Tools & Compressors
Want info about Husky air nailer 1107
How to remove stucked nail?
  • 125 Answers
SOURCE: won't feed nail
This happens to my gun too. You probably need to oil the gun once in a while. Here is how you fix it:
Disconnect the gun from the compressor first don't wanna get hurt or anything like that. There is a pin that shoots the nail out well that pin is jammed so what you have to do is push that pin to the original position. using a flat head screwdriver would help you to push that pin back into place. Let me know how that turns out please. I pretty sure that is the problem with your gun. Make sure you lubricate the Nailer once in a while.
Posted on Oct 02, 2008
  • 2176 Answers
SOURCE: air nailer won't nail
If youve never done anything to it could be a couple things. Have you kept it oiled (about 6-8 drops) before using and again at lunch if construction type work. Check the nails to make sure they move freely in the magazine Check the nail guage for proper size. and what I would do is fire it till it skips disconnect the air from tool and open the front door (for removing jams) and see the driver position. If it is partially down that would be the problem, check the driver for being bent. Lastly remove all nails and just tap the nose on a piece of wood and again check the driver position, if it moves or falls freely then the tool would have to have new rubber which might be a good idea anyway. Get back to me with the model number and I will research and see if they make an o ring kit.
Posted on Jan 21, 2009
  • 195 Answers
SOURCE: framing nailer not setting nails
Dear cjcoolair,
No need to replace any parts. There should be and allen screw type adjusment somewhere near the front plate where nails exit so as to adjust depth,may be black plate with arrows up or down depending ---loosen screw,push up/down as needed,tighten test and reset as needed.
Please rate.jj
Posted on Apr 05, 2009
  • 1388 Answers
SOURCE: brad nailer not firing nail...can hear brief air noise upon pulling the trigger
Porter cable makes a number of brad nailers (18 gauge) that very quickly suffer from the problem that you are having. You did not mention the model number of your gun but if it is one of these, (bn125a, bn200a, ns100a) kit # 60061 will fix the problem. It costs between 25 and 30 dollars. Google that part number or order from Dewalt owns the porter cable brand. Before you order the kit, check that the driver blade is not bent and stuck. The driver should travel freely down the cylinder. When you install parts, use Danco silicone grease to lube (availabel at Lowes in the plumbing department) If your model # is different from those mentioned above, please email me and I will recommend a repair.
Posted on Apr 27, 2009
  • 2176 Answers
SOURCE: air blows thru the trigger on both my finish nailer and staple gu
there is an o ring in the trigger valve referred to as a Purple o ring that is probably split. If you can find a air tool center that has them you will save a lot of money versus replacing the trigger valve. Let me know what you are going to do and I will help you with the removal of the valve.
Posted on Oct 06, 2009
I have a nail jammed in between the push rod and the push rod guide. The nail somehow was in backwards so what I have is a very jammed nail. How do I get the nail out of the nailer?
Hi Johnny, First thing to do is make sure that the tool cannot fire any nails. so remove the airline or, if it's a gas powered (Fuel Cell) tool remove the battery and fuel cell.
If you can, try and remove any of the nail that you can. Then CAREFULLY try and push the driver back into the cylinder. This may take some time. Sometimes we end up having to strip the tool down to remove the magazine, this will allow better access to the stuck nail. So far, I've never been stuck doing this but.....
Sep 20, 2013 | Ridgid Full Round Head Framing Nailer...
I pulled a stuck nail out if my dewalt nailer now it won't push nail through
Ok you took the stuck nail out of the gun where it was stuck with the driver, yes. If so, Take air off,, take a long skinny screw driver and stick it in said hole and check to see if driver has returned the stroke backwards to a ready to fire position. If you feel the driver still forward push it backwards all the way. Remove all tools,, load a clip, hook the air hose and fire. if you get a nail (success) but if it fails after this shot and the same problems start all over again the chances are the driver is broken..
Sep 04, 2013 | Dewalt Air Tools & Compressors
How do you remove the front hub to remove the stuck nail
If a nail is stuck between the driver and nose of the gun, you will need to forcefully push the driver back into the gun. Remove the head and cylinder and place the body of the gun on piece of plywood with nose pointing up. Using very sturdy steel rod, hammer the driver down. The steel rod needs to be slightly thinner than the driver to allow for the stuck nail. I use a broken driver ground thinner on the side that will need to bypass the stuck nail. Careful when striking hard steel with hammer, could spinter (I use a heavy brass hammer). Good luck
Nov 01, 2011 | Stanley Bostitch F21PL Nailer
Craftsman evolv braid nailer leaks air around the trigger when i try to nail. it does not nail sears no. 00915206000 mfg no. 42081 (for kit) on gun model:6G28/F50
Air leaking from trigger when trying to nail indicates that the headvalve is stuck or headvalve orings are dry and allowing air to pass. Remove the head and pull out the headvalve piston. Examine orings for cuts or broken (replace as needed if orings worn and cannot make seal). If headvalve was stuck/dry, lube with plenty of silicone paste lube (sold at Lowes in the plumbing dept. ). Should be good to go. Good luck
Jun 30, 2011 | Craftsman 184060184070184080 Brad Nailer...
When firing nailer first nail shoots good but next nails head will get stuck between the push rod chamber. push doesnt seem to return fully top when nail is cycled.
Try oiling the tool first. Remove the nails, squirt a decent amount of air tool oil in the stem where the air hose coupler connects, and fire the tool a dozen times or so. Then put in the nails and test. If it still hangs up then it will need the o-rings replaced.
Jun 11, 2011 | Porter Cable Coil Roofing Nailer
When I pull the trigger it will not fire a nail, air running through the nailer is all that will happen?
You could have a nail jammed. Remove the front assem. where the nails come out and see if somthings stuck like a nail.
Jan 23, 2011 | Dewalt Clipped Head Framing Nailer
I have a bostitch SB 16 finish nailer that has a rack of nails stuck in th loading barrel. I need to take the barrel apart to get them out, How do I do this?
The solution provided is harder then it needs to be. Where the nail gun handle attachs to the nail magazine there are 2 bolts. Remove these bolts and the nail magazine slides right out and you can get to the jammed nail. It still took some effort on my part to get the nail out but this was a lot easier then removing the 4 bolts previously suggested.
Jun 30, 2009 | Stanley Bostitch F21PL Nailer
N80 suddenly quit working
There is a nail stuck inthe grove where the nail comes out. There are 4 allen bolts on the front of the nailer.remove them and you can remove the bent nail. Put it back together and your ready to go.
Mar 11, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Air Tools & Compressors Logo
120 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
