Question about Verizon Communications enV2 Cellular Phone
Keep hearing "command not recognized"
On my env2, every time i turn off vibrate, send a text message or change a setting, my phone blares "Command not recognized please try again" even though whatever im doing works. its just really annoying to always hear that when im texting. how do i turn that off?
  • 4 Answers
Well. the problem is that you're probably hitting the command button where you sumbit voice commands like: call "mom".
its a stupid thing to put on a phone, and I've never seen anyone use it. but whatever, verizon's stupid.
again, the voice command key on the enV is the clear button. so if you hold it down, you'll hear the "command not recongnized, after you hear "please say a command".
your hearing it over and over again because you accidently hit it, and since you dont say anything after the beep it gives, it goes "command not recongnized". i dont think it says "please say a command" when its on vibrate, but i couldnt be sure.
hope i helped :)
Posted on Jul 20, 2009
How do I turn the voice command off on text messages
To turn of this setting:
1. From the home screen, press the Voice Commands key on the right side of the phone. The Voice Commands screen appears in the display. 2. Press the right soft key Settings.The following options appear in the display:
• TXT Msg Readout: Reads out the text in a TXT message. (Turn this off)
Jan 04, 2015 | Samsung SCH-U450 Cell Phone
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 6 Answering System On
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
0 then 9 Answer System Off
1 then 0 Help Guidance
Command Function
0 then 1 Repeat a Message*
0 then 2 Playing incoming Messages
0 then 3 Skipping a Message
0 then 4 Deleting a Message
0 then 5 Stop Operation
* For Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
** For Memo Record and Greeting Message Record function, the first time you enter
the corresponding command, it starts the Recording function. If you want to stop
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
My env2 wont send text messages. what can i do?
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Nov 11, 2010 | Verizon Communications enV2 Cellular Phone
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
When I recieve text messages my Lg xenon ''talks'' . For instance it will say ''message from ...'' I can not figure out how to turn this message alert setting off, I have looked everywhere on the phone but...
You need to disable Call Alert in your Voice Command settings...go into menu - settings - more - application settings - voice command. The last option on the list will be Call Alert, change to ring only.
Jul 31, 2009 | LG Xenon GR500 Cell Phone
LG env2 will not save text messages
This happened to me. My problem was that i had a memory card, and i accidently put the save options for my pictures to my phone memory instead of to card memory. So it messed up my phone.
May 30, 2009 | Verizon Communications enV2 Cellular Phone
When a new text or call is says Message/Phone call from....."
Go into phone settings, then voice commands, then call alert. Set it for ring only. I have the EnV2, so it could be a little different, but thats how i do it on my phone. Good luck.
Jan 29, 2009 | LG enV VX9900 Cellular Phone
How do I retrieve my voice mail when I'm away from home?
this instruction may help you , if not a model number could help , but try these instructions . thanks
To operate from a remote location, use any touch-tone telephone, and follow these steps:
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 57).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following chart:
Remote Commands
Command 0 then 1
Repeat a Message*
Command 0 then 6
Command 0 then 2
Playback Messages
Command 0 then 7
Memo Record/Stop**
Command 0 then 3
Skipping a Message
Command 0 then 8
Greeting Record/Stop**
Command 0 then 4
Deleting a Message
Command 0 then 9
Answer Machine Off
Command 0 then 5
Stop Operation
Command 1 then 0
Help Guidance
we can get a link to your manual if we had model number
Dec 30, 2008 | Uniden 5.8GHz Dual Cordless Phone
I can't get rid of the tone when a message is sent
have ya tried this . may be of some help i hope
go to
text message ,select
scroll down to no.5 settings,select
text message,select
sending options
check the delivery report is turned off or unticked .
riz.
Aug 20, 2007 | Samsung SGH-E900 Cellular Phone
Verizon Communications enV2 Cellular Phone Logo
170 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
Bee Santiago
TO Lady
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
