Question about Cell Phones
I LIVED IN THE MIAMI AREA, HAVE 2 NETTALK PHONES AND ARE UNABLE TO USE THEM. THE CHAT SAYS THAT ARE TECHNICAL PROBLEMS. ANY IDEA HOW LONG IS GOING TO TAKE?
Area code 305 where is it
Area code 305 is the area code for all of Miami, Florida, Miami-Dade County, and the part of Monroe County in the Florida Keys in the United States. The mainland portion of Monroe County is served by area code 239. The numbering plan area 305 was overlaid by area code 786 in 1998.
May 03, 2017 | Cell Phones
What happened to netTalk? HONE WENT OUT AND NO WEBSITE ANYMORE.
Website is there
http://www.nettalk.ca
That said, they do have problems from September 22, 2015
http://www.themiddlemarket.com/news/restructurings/troubled-telecom-business-nettalk-adds-lawsuit-to-list-of-problems-258184-1.html
Nov 20, 2015 | netTALK DUO Wi-Fi VOIP Internet Phone...
Nettalk customer service
Go to: https://www.nettalkconnect.com/login
Login to your account, click the "Click Chat" under "Logout" (near right top of page) to converse with a CSR to find out the answers to your question.
Aug 12, 2014 | netTALK DUO2 VOIP Telephone Service
Problems with nettalk
Jul 22, 2014 | netTALK DUO WI-FI VoIP Gateway
Lose nettalk connection from router after on phone for twenty minutes
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 28, 2013 | netTALK DUO Wi-Fi VOIP Internet Phone...
My nettalk duo's red light is constantly on .its not working. how can i fix it.
ANSWER : I have had the solid red light come on every so often. I would power cycle the nettalk and it would be find for a while, then go out again. The solution is to assign the nettalk device a STATIC IP that is outside of the range of ip addresses assigned by your router for DHCP.
Example, my linksys e1200 router by default assigns DHCP addresses starting at 192.168.1.100 and goes to 192.168.1.149. If you assign the mac address of the nettalk to an ip outside that range (that is not 192.168.1.1 because that is your router) like 192.168.1.20 it will solve this issue. whenever the nettalk connects to the router, it will always get 192.168.1.20, I think the nettalk can't handle getting different ip addresses from the DHCP server.
Then tTurn off the nettalk, then do a power cycle on your router.
Feb 11, 2012 | NetGear Computers & Internet
When i open my windows my magicjack doesnt open the magicjack install component setup shows this, the installer failed to exit a running instance of magicjack
Uninstall all components of your fist installation.For that you can use REVO uninstaller to erase all traces from the MJ installer.Then try again.
Oct 03, 2011 | magicjack.com
I just setup Nettalk Duo and can send and receive calls. But the Answering machine will not work. I have it set for 4 rings and Nettalk voicemail is set for 5 rings. Any suggestions, please help.
Login to your Nettalk account and click on the voicemail tab on the left. Make sure to turn off your voicemail settings for your Nettalk device and save settings. Your answering machine should now pick up after 4 rings.
Mar 11, 2011 | Uniden DECT 6.0 Cordless Phone ID
Have an SBG6580 and purchased a NETTALK DUO (VOIP). Which is trying to connect but can't. Tech support at Nettalk tried to change some settings but it looks like modem is still blocking the port. ...
The only way I got the NETTALK DUO to work keeping my SBG6580 is to use it in cascading mode with my old Linksys router. When I plugged the DUO into the Linksys it worked great.
Nov 14, 2010 | Motorola Computers & Internet
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
