Question about Husky Garden
Husky 1107 assembly - Husky Garden
Unversal remote CYBERTEC RM-L 1107+3 list of code for philips tv
Below are all the possible codes.
Philips TV Remote codes:
0037 0054 0556 0056 0238 0012 0721 0000 0554 0019 0191 0020 0087 0774 0193 0747 0423 0187 0186 0343 0178 0108 0570 0024 0374 0028 0030 0092 0032 0051 0772 0009 0200 1154 1454 0080 1756
Mar 24, 2017 | Philips Televison & Video
How to replace broken trigger on a huskie 162 sg chain saw
Most Husky saws have a small pin to drive out to remove trigger. Often safety lever on top needs to be removed also. Sometimes tank/handle assembly needs to be removed to replace trigger.
Dec 27, 2016 | Garden
We're can I purchase the muffler and everything that goes with it
Any chain saw store should be able to get what you need. Check what kind of saw you have, model number, etc. and then use the internet to find a way to order parts.
Sthil and Husqvarna are two different brands.
Husqvanrna saws are often refereed to as Huskys
Google Search "345 Husky muffler parts":
Google Search "chainsaw parts / Stihl, Husqvarna":
Apr 23, 2014 | Solo 662 667 Chainsaw Muffler W/ Bolts...
SPRING URETHANE BLACK 12.7MM ID X 25.0MM OD X 38.1MM TH , DUROMETER ; SHORE 95A, B-116-064 for my jazzy 1107 Power Chair are cracked and busted causing my rear wheel caster assembly to lean backwards in...
I know that 95 durometer EVA is available from other sources like shoe findings suppliers. This is about 1/2" by 1" by 1.5" and if a mechanic was able, he could fix you up with that. If that is what you need, they could help you out without having to replace the whole assembly.
Feb 28, 2017 | Health & Beauty
Husky power washer 2600 Tried fixing starter
I'll send you a link to a great video of how to recoil a starter spring, so you wont lose and fingers or eyes. :)
Aug 01, 2013 | Garden
Tile saw thd9501 Husky I need a parts
Grinder/motor assembly is sold as a complete unit only. The cost is over $129.00. My opinion, scrap it, but one at Harbor Freight (get the lifetime warranty (just a few dollars more), any problems, they replace the unit wiht a new complete saw. The quality is no worse than the Husky you own now.
Feb 10, 2010 | Measuring Tools & Sensors
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
Dec 20, 2009 | Air Tools & Compressors
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
Enter 261 (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
See the Chain Brake Assembly detail. HTH
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
Husky 145
Usually when a machine is totally jammed, it's either (a) because a bunch of upper thread has gotten jammed into and around the bobbin assembly so thoroughly that the assembly can't turn at all, or (b) the needle is jammed down the hole so thoroughly that nothing moves.
If both of those places are clean and empty. . . then "Never mind!"
May 01, 2008 | Husqvarna Husky 145
Garden Logo
35 people viewed this question
Top Husky Garden Experts
Andrew Taylor
Andrew Taylor
Are you a Husky Garden Expert? Answer questions, earn points and help others
