How to set up my receiver - Audio Players & Recorders
Picture does not fill the screen
More information would be helpful. Check the screen settings on the TV. In addition, when my Dish receiver was set up the tech did not set the receiver to 16:9. This resulted in the HD programs taking on a letterbox effect with black bars on top and bottom. Compare picture from different sources (i.e. over air versus cable or sat receiver to determine if problem is with TV set up or receiver set up). If problem with receiver, verify output is set to 16:9 and not 4:3.
Sep 17, 2013 | Televison & Video
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
What are the factory default settings? What will I have to redo after the factory default settings are set?
Any customized setting you changed on the receiver will go back to factory default. Here is a list of the settings that would change:
  • Favorites Lists are cleared and the titles set back to List 1 - List 4
  • Search History is cleared
  • Alternate Audio is set to English
  • Closed Captions returns to default settings
  • Mode Reminder is enabled
  • Receiver is set to Dual User Mode
  • Caller ID history is cleared
  • Phone Setup is set to Touch Tone and No Prefix
  • Audio Output: Decoder set to Dolby Digital/PCM
  • Updates are set to 3:00 AM
  • Guide text is set to Small if the receiver is connected via HDMI and Medium otherwise
  • Guide format is set to Standard - Partial Guide with Video
  • Inactivity Standby is enabled
Locks, timers, DVR and Remote Address settings are not altered
Aug 19, 2011 | DISH Network ViP722 DTV Receiver /...
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
HOW DO I SET UP TO RECEIVE FAX
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Jan 28, 2010 | Office Equipment & Supplies
The fax will not receive automatically even though it show's as being set to automatic
This issue can occur when the receive-to-PC setting was previously enabled for the PC connected to the printer, and the user is trying to enable this feature once again without disabling the previously enabled setting. This is because the receive-to-PC setting can be activated only from one computer.
Perform the following steps in the correct order to re-activate the receive-to-PC setting:
1. Turn the receive-to-PC setting off from the all-in-one printer control panel.
Here are the steps to be performed from the printer:
a. On the all-in-one control panel, press Menu .
b. Use the < or the > (left or right arrow) button to select Fax functions , and then press Enter .
c. After you selected the Stop Recv to PC setting (any faxes that remain in the all-in-one memory are printed).
2. Next, to turn the receive-to-PC setting on from the printer software, perform the following steps from the printer:
a. Open HP ToolboxFX .
b. Select the HP LaserJet 3050 / 3055 / 3390 / 3392 all-in-one.
c. Click Fax .
d. Click Fax Tasks .
e. Under Fax Receive Mode , select Receive faxes to this computer .
Performing the preceding steps should ensure that the user is able to select/activate the receive-to-PC setting.
Aug 07, 2009 | HP LaserJet 3050 All-In-One Printer
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I have no sound when i plug in my speakers
Make sure you are plugging into output at the back of receiver/ not input. Also make sure you set receiver on corresponding output on menu. If your playing a cd make receiver is set to cd and the output on back of receiver is on the same setting.
Oct 13, 2008 | Audio Players & Recorders
Setting up receive set top box and tv for surround sound
Plug the TV to an open channel on your receiver via this output:
*Rear, 1 x Digital audio output (coaxial) ( TOSLINK )
This will look like a single RCA output plug.
Set that input channel on your receiver to some sort of virtual surround mode because it doesn't look like your HDTV has a decoder in it (meaning it will come out stereo and the receiver will have to fake it).
Turn the volume all the way down on the TV and use the receiver to control TV volume just as you do with DVDs.
*Substitute this with the digital audio output on your set top box if you are sending video only to the TV from the set top box (component, DVI or s-video connections). So video goes to the TV, audio to the receiver.
Feb 03, 2008 | Televison & Video
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
23 people viewed this question
 Grubhead
Grubhead
