Question about GE Microwave Ovens
How do I reset GE microwave
Model J ES733WV003
Reset clock on over the range microwave
Go to this link....you can download the users manual. The procedures for setting the clock are on page 22 of 68.
JVM1950SR1SS GE MICROWAVE Manual
Nov 02, 2014 | GE SpaceMaker Microwave Ovens
MY GE SPACESAVER MICROWAVE MODEL JVM-1653-SHO-1 SHUTS DOWN AND TELL YOU TO REPROGRAM THE CLOCK BUT YOU RESET USING ALL INSTRUCTIONS I INSTALL COOK TIME PRESS START IT WILL COME ON FOR 3 SECONDS AND SHUTS...
This is magnetron-related.
See
this FixYa solution (solution #2) even though your model number is different.
Jun 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave Model JEM31SA, intermittent problem with keypad going dead after cooking. Have to go out and flip breaker to reset. It prompts for clock set info and functions normally again after...
You're going to have to replace the keypad module and possible the control module (do the keypad first). You can try contacting these folks: http://www.appliancepartspros.com/search.aspx?model=jem31sa%20001%20ge%20spacemaker%20microwave
And see if they have a keypad for your unit. Depending on the age of your microwave, you may be best off replacing the whole microwave.
Aug 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650SH01 Microwave starts cycle but as soon as heating starts it shuts down and requires clock and date reset. Sometimes resets and works but now will not stay reset.
You have a bad or loose magnetron.
See
this FixYa solution. even if your model number is different.
Aug 20, 2010 | GE Microwave Ovens
Microwave resets after start
See this FixYa solution. even if your model number is different.
May 23, 2010 | GE JVM1650 1000 Watts Microwave Oven
Reset shows on display of my GE space saver microwave oven
change the board that has the reset on the display board it is bad
Mar 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE model JVM1653 has problems when heating I
Take the 2 screws out of the top outside grill. Take the 1 screw out of the top of the control panel. Lift the panel slightly and it will tilt out and hang there. Try a cook cycle with the panel in this position. If it works, your problem is interference from your magnetron. It is very common on these units. I do not recommend adding EMI shielding with tin foil as many have been suggesting on the help sites. If you are still under warranty, call GE. If not, call GE and threaten to sue. This is a known problem with these units and they should have been recalled.
Mar 15, 2009 | GE JVM1653 Microwave Oven
Microwave stops running after 3-5 seconds
hade same problem upper door switch by past it microwave works
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Microwave Oven model JE2160. The clock and time are 10 seconds fast per minute.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise, the manual may address some settings. You can download GE owner's manuals here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Microwave Ovens
Microwave Ovens Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
