Question about GE Refrigerators
I have GE French door bottom freezer with ice maker .First time hooking up ice maker I pushed the ice on button and water is turn on in the line what next or how long will it make the first ice cubes
  • GE Master
  • 15,557 Answers
First make sure the ice maker is active, there may a switch or a bale that needs to be moved into position.
Posted on Dec 07, 2016
GE french door bottom freezer will not make ice
HI.DIFFICULT WITHOUT A VISUAL.BUT TRY MANUALLY PUTTING SOME WATER ON THE ICE TRAY AND TRY.IF ICE DROPS ONCE THEN IT COULD BE THE VALVE BRAKE IN THE LINE OR THE ICE MACHINE ITSELF GOOD LUCK ALI
Jul 12, 2012 | GE GFSS2HCYSS 22.0 Cu. Ft. Stainless Steel...
Every half hour or so it sounds like a power surge...an electrical sound coming from the upper section of my French Door bottom freezer refrigerator. I do not have the water hooked up for ice making...and...
You have a problem with the control board program. If the ice making button is turned off, the ice maker should stop working completely but it sounds like it's wanting to make ice.
Jun 28, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Inside filter water dispenser suddenly stopped working. New filter removed and no working with or without filter . Water line is fine. Ice maker works.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Mar 18, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
NOT MAKING ICE JUST HOOKED UP WATER LINE AND TURNED ON TWO HOURS AGO
if you have just purchased the ref. and hooked it up it will take 24 hours for the ref. to get to correct temp.Plus the ice maker wont start to work until the freezer temp gets to 15 degrees.if the ref. has been in use then check the power button on the ice maker itself and make sure the power is on.
Nov 03, 2010 | LG LFC22740 Bottom Freezer French Door...
Our GE Profile Ice maker is not making ice,and water is not cold?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | GE Profile PFS22MBS Bottom Freezer French...
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Ice maker does produce much ice.
Change your water line with a new plastic line kit. Before you hook it up, get a bucket and turn it on and see if you have enough pressure. It should squirt very hard.
Jan 07, 2010 | LG LFC25770TT Bottom Freezer French Door...
Samsung Ice Maker--Ice block and now no water flow...
Wait a few hours before you jump to conclusions. All depends on the position of the cam.
Aug 23, 2017 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
