Question about Health & Beauty
Where do you plug in the battery charger - Health & Beauty
No light comes on my charger when i plug in my new p103 battery into charger no 1423701?
does the outlet work that the charger is plugged into... is the battery completely dead and the charger can't see it... is the charger even plugged in... or is it even any good ???
Oct 23, 2013 | Ryobi Multi-Volt Battery Charger
It keep giving me a message to plug in my charger because my battery is going dead so i bought a new dell charger the original one that goes with the netbook, and it worked for awhile, but now its telling...
it might be the battery, i had the same problem with my netbook the charger is ok but the battery died i can use it if it is plugged even if the battery is dead.you can tried taking the battery off the netbook if it turns on the charger is ok.
Sep 13, 2013 | Dell Inspiron Computers & Internet
My laptop is working only via battery
That means your Ac charger is bad so you have to look for another charger of thesame specification voltages and use
Jan 02, 2013 | Computers & Internet
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Plugged in to charge battery, red light flashing, no green light on, charged all night still flat, what could be the problem.
Hi. Sounds like there is no connection between the charger and the batteries. The charger uses the voltage in the batteries to regulate the charge. If the charger is not connected then the charger will not operate at all.
The fault can be a broken wire in the charger plug, or faulty charger socket on the scooter. Can be caused by faulty battery connectors, or wiring from the charger socket to the batteries.
Try moving the charger plug in the socket while the charger is operating. These sockets sometimes wear and dont contact properly.
The best way is get someone with a multi-meter and try and trace the fault for you.
Good luck. Neil.
May 28, 2010 | Pride Mobility Products Hurricane PMV...
New batteries does not seem to fully charge. tested the output of the charger with meter and it shows no voltage on the output of the charger, but the two lights flash quickly when plugged in to the wall...
The measurements below are for a 12 volt charger or across one battery at a time. In a 24 volt charger or across both batteries at once, double the values.
The charger will not show any output unless connected to a battery. To test the charger, attach the charger to the battery but do not plug in the charger. Connect a meter to the battery and read the voltage (9.8v - 11.6v).
Now plug in the charger. Read the battery again (13.6 - 14.2v).
The voltage must not be higher than 14.8 on the battery or the battery will over-charge - the charger needs service. If the voltage does not come up to 13.2v, the charger is not running. Again, the charger needs service.
Be patient. You can wait ten minutes and measure again. Batteries respond slowly to the charger.
Apr 02, 2010 | Pride Jazzy 1113 Power Chair
I have a pair of sp10 and having trouble charging them and the batteries are new and when i put them in the charger i have to turn them on for the chargeing light to come on is this normal or are the...
You do not mention if you are using a wall plug charger, or a drop-in charger. We will give troubleshooting tips for both. To answer your question: If the light comes on and stays on, on the charger your charger is good. You have a radio or battery problem.
Wall Charger:
The light on the HTN8232 wall charger should come on and stay on when plugged into the radio, with the radio turned off. The fact the light comes on when the radio is turned on indicates your batteries are either no good, too low to charge, or you have a battery contact problem.
Solutions: 1) Clean your battery contacts with a pencil eraser.
2) Be certain the batteries are installed correctly.
3) Check your battery date code (three digit number on back of battery above the stop sign. First number is year, next two numbers are the week of the year. Batteries last about 2 years.)
4) Check to see your new batteries are NiCd batteries. The wall charger method is not compatible with NiMH batteries.
5) Try a charged battery from another radio and see if the charger light comes on and stays on with a different battery.
Drop-In Charger:
If you are using a drop-in charger, you would be using the above listed HTN8232 wall plug charger plugged into the tray. Here are some possible solutions for the drop-in charger:
1) Clean the exterior battery contacts with a pencil eraser.
2) Check to see if the wall charger will work when plugged directly into the radio.
3) If the charge capability of the radio seems compromised, take the battery out of the radio and charge it alone in the drop-in charger.
NOTE: Do not use the PTT if you are turn on the radio when plugged into the charger. This will burn out components in your radio.
The SP10 radio is known to be a repairable radio. (Generally around $69 flat rate.)
Best regards.
Dec 05, 2009 | Motorola Walkie Talkie 2-Way Radio
Health & Beauty Logo
74 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
