Question about Dryers
Can an Electric dryer get tooo hot?, If so some troubleshooting ideas or suggestions. Thank You
The back of the dryer gets hot, not enough that it can not be touched, but hotter than you would expect.
    Top Expert:
  • 8,204 Answers
Read this link it might help you out. http://www.partselect.com/Repair/Dryer/Too-Hot
Posted on Dec 07, 2016
Dryer not heating
Hi
There are various factors as to why an electric dryer is not heating. A burnt out heating element, A blown thermal fuse. Even wiring connections. Please check the bellow links to troubleshoot your problem:-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#theresnoheat_electric
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 02, 2011 | Kenmore 62602 Electric Dryer
My dryer does not start at all when I push the start button.
Hi
Please check the link bellow to troubleshoot your problem when your dryer is not starting:-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itdoesntworkatall_electric
Feb 01, 2011 | KitchenAid KEYS700LQ Electric Dryer
My dryer does not start; when I press the cycle bottom it does not light; but when I open the door the inside light turns on. ]
Hi
Please check the bellow link to get a detailed idea as to the problem of your dryer:-
http://www.repairclinic.com/Dryer-Troubleshooting?red=Dryer-Repair-Help#itwontstart_electric
Feb 01, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer does not get hot enough to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | GE DBXR463EDWW Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Relaced thermostat and therma fuse, now dryer is tooo hot
Sound like the thermostat is not working bud first check and double check the thermostat is connected properly and the wires are on correctly (not mixed up)and check the stat probe or bulb is in the correct place to pick up heat(assumeing that the stat is not a energy switch wich has no bulb)If you are not sure where the wires go there should be a diagram on the inside of the back panel or go on line to the manufacturer site and get one from them,
Hope this is of some assistance
Jan 19, 2009 | Maytag PYE2300AY Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
HotPoint Elec dryer heats up but doesn't dry
yes you have a vent restriction something is blocking your airflow it needs to be an open 4 inches all the way and clear describe your vent to me are you using plastic behind the dryer is it short or all mashed up don't move the dryer get a flashlight and look over the back like its sitting and describe your vent to me from the dryer to the out side if its plastic and looks like a python then you may have found your promblem
Mar 31, 2008 | Hotpoint TDC32 Electric Dryer
Either the heater element is breaking or is loose and getting only 110V instead of 240V.  First I would check the wall outlet with a voltmeter for 240V between Line1 and Line2.  Also check the connections and continuity for the heater element.
Oct 11, 2007 | Roper REX4634KQ Electric Dryer
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
Dryers Logo
Top Dryers Experts
