Question about Refrigerators
Hi what error code "F7" on the monitor of Hisens refrigrator freeser model RT-41WC4SHYSS?
    Top Expert:
  • Refrigerators Master
  • 79,847 Answers
Please contact the manufactuer on this. http://www.hisense.co.za/manuals-and-guides
Posted on Dec 07, 2016
3 Suggested Answers
  • 1891 Answers
SOURCE: We get a F7 error code on our model JT910SA3SS
F 7 code is an most G E ranges . is stuck key on pad . some of these can be unstuck but if hi heat caused the pad is warped and not repairable . turn off power disconnect the key pad from the clock and if code goes away key pad is at fault if it does not the eoc is at fault . and you will have to replace the clock . **** hope this helps . feed bk pls .
Posted on Dec 26, 2009
  • 18 Answers
SOURCE: GE Profile Wall Oven Model#PT916S error code F7
U have a bad clock or your probe inside of oven is bad.I would replace your probe first .it looks like a rod sticking out inside back upper top .f7 I believe means its not reading up temp and getting to hot
Posted on Nov 10, 2011
I have a Kenmore Elite Speedcook Microwave oven, model #665.63783600. What does error code F7 mean on this model?
F7 Error Code On Microwave Ovens With Inverter Board
An F7 error code could be an inverter board failure. Anything else that prevents microwave energy may also cause an F7 error, and must be checked. The technician should perform the following procedure to test for an F7 error code:
1. Check the magnetron.
2. Check the magnetron TCO (it should be closed).
3. Check the 3 interlock switches.
4. Check the harness wiring.
5. Check the electronic controls.
6. Check the inverter board.
For more free help, feel free to contact me via my site with your detailed symptoms and full model number and FCC ID number as shown on the tag in or on the oven.
Nov 18, 2016 | Kenmore Microwave Ovens
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
F7 error code on GE gas oven model # JGBP90MEA2BC
On this model, code F7 means there is a keypad malfunction, and therefore the range's "computer" isn't getting a valid signal from the keypad. It may be a stuck "touch-key", a bad connection between keypad membrane and the range/computer connector, or more probably a faulty keypad membrane.
In some cases it can be a defective computer module. You can test whether the problem is the keypad or computer unit by disconnecting the keypad entirely. If an error code F7 still shows, then the computer is faulty.
If this was helpful, please rate via the helpful button.
Nov 04, 2014 | Kitchen Ranges
Nov 10, 2011 | Ovens
Monitor says Ready to print but when I hit F7, nothing happens and error code 101 shows up.
Hi
You have a fatal error
You need to replace printers motherboard
Pls vote us to keep us alive
Nov 21, 2010 | Paxar Monarch 9855 Thermal Printer
Dec 26, 2009 | Ovens
Ice maker won't make ice
check the temperature settings and if its normal then check the compressor for enough refrigrant in it for this you should call deep freeser technician.
Aug 07, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
