Question about Frigidaire Refrigerators
Frigidaire r134a the freezer is not cooling but the fridge is working
  • yadayada
    yadayada Dec 07, 2016
    Verify the model number, R134a is a type of refrigerant.
    Novelist:
  • 112 Answers
Bobby, I'm not sure what refrigerator you have but are you sure your refrigerator part is working? Did you actually measure the temperature in it? It should be around 40 deg F. The reason I ask this is because in most cases, the refrigerator portion of the unit receives its cold air from the freezer. This suggests that you can't have a problem in the freezer section without a problem in the refrigerator section. You may want to clarify this point before you move on with the diagnosis.
Posted on Dec 08, 2016
HVACRH20
  • 237 Answers
SOURCE: Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Posted on Dec 27, 2006
SOURCE: Refrigerator not cooling freezer working fine
Refrigerator suddenly not cold enough . Drip pan clean and dry. No dirt or dust.
Posted on Oct 06, 2008
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
farfield
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
joecoolvette
  • 5660 Answers
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Posted on Jul 05, 2009
MY Frigidaire Refrigerator is 2 years old, the Refrigerator is not cold, but the freezer is working fine, what is common fix?
Most will tell you the freon is bad. but i have found in most cases the freezer works but fridge doesnt.. I have found the solution to be a bad cooling fan on the fridge it self. if the fan is not cooling the fridge will not cool. You could pull the fridge out and see if you can see the fan turn it on hi and when the fridge kicks in see if the fan or fans are working.. dust can cause them to slow or stop.
Jan 06, 2015 | Frigidaire Refrigerators
Fridge freezer is two years old. freezer is working but it is freezing up and the fridge is not working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Frigidaire Refrigerators
Frigidaire 16.5cu top mount not cooling fridge. freezer is froze
The baffle that opens to allow cooling into the refrigerator may be blocked, broken or mis wired. These units work by just cooling the freezer and then blowing some cold air into the refrigerator whenever the fridge thermostat calls for it. The fridge's thermostat is trying to cool the refrigerator but something is preventing the cool air from getting to the refrigeration part, that's why it's freezing up the freezer
Mar 13, 2010 | Frigidaire FRT17B3A Top Freezer...
Model R134a Refrigerator...Freezer works fine but no cooling in the refrigerator... What can I do if anything besides replace it?
Two things, One, the coil in the freezer could be Iced up, deforst the freezer.
Two, the circulatng fan is not running.
Sep 01, 2009 | Frigidaire Refrigerators
Fridge not cooling
low gas level in the system r134a gas
Aug 12, 2009 | Refrigerators
Oct 05, 2008 | Randell 20072SC R-134a Refrigerator
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
