Question about Coffee Makers & Espresso Machines
Can't make a decaf with my Xelsis Evo machine!
I am trying to make a decaf coffee using my brand new Xelsis Evo coffee machine. Every time I follow the exact directions, when I hit 'OK' the machine displays 'Max Brew group pressure' and it switches off. Making regular coffees with beans being ground works fine. This only happens when I use ground decaf coffee. Any suggestions?? Thanks!
  • 12 Answers
SOURCE: Coffee does not brew
The thermal breaker has died in it. This is usually mounted on, or near the heating elementm and usually turns off when excessive temperatures are present (such as when a pot boils dry, or the unit is left on for days) It can be checked with a ohm meter on its contacts. If it shows as good, it should show up as normally closed. Some overtemp breakers have a small button for resetting, but most are simply supposed to reset themselves once the heat is sufficiently reduced. There are also heat fuses that blow...for good when excessive heat is detected, mounted in the same place, they are often a metal bullet shaped tube. OR.....your power cord...or main power switch could also be faulty.
Posted on May 01, 2006
SOURCE: Saeco magic comfort coffee machine grinder
Empty beans out. Take the two screws out.
Put bean grade to 1. Run the machine as if making coffee. Use a vacuum and clean the bean grinding machine area. Run the machine again.
Place bean container back and put screws back in. Fill bean container.
This worked for me
Posted on Aug 30, 2008
  • 1089 Answers
SOURCE: need to take out brew group jammed
Hi
Look on the left side where the box should be. In the left side towards the botton there is a long opening. Take plastic knife and slide it in while the machine is on and blinking and see if the brew unit will cycle. The drip tray has to be in for this to work. There is a metal bar that has to be pushed toward the rear of the machine to cycle the brew unit.
Posted on May 22, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
SOURCE: Saeco Incanto S-Class Sirius coffee machine not sensing beans.
I have had the same problem the only way I could get it to brew would to use the program quantity feature every time. I was going to take it in today and decided to restore the factory settings and now its working like it should. This seems to be a circuit board issue Ouch! I have another issue with the steam, if I take the knob off it works if I don't it doesn't glad I bought a 2K model GRRRRR!
Posted on Jan 25, 2010
Is the Safeway select bold French roast coffee decaf?
will have that fact on the label
no decaf word --not decaf
Nov 24, 2017 | Coffee Makers & Espresso Machines
Saeco xelsis coffee grounds on drip tray and inside the machine , lots of it.
The water overflowed the coffee grounds when making the coffee.To much water or coffee grounds wrong filter....Good Luck
Oct 02, 2017 | Saeco Coffee Makers & Espresso Machines
My em 200 cuisinart espresso maker stops brewing and beeps
My em 200 Cuisinart express
maker start and stop and beeps what I do
Jan 14, 2013 | Cuisinart EM-200 Espresso Machine
Why is my coffeemaker taking more than 4 minutes to brew a pot of coffee
  1. Be sure that your SPEEDBREW® Coffeemaker brew control dial is set to 'Brew Regular' when brewing regular coffee. Please note that using the 'Brew Decaf' setting will slow the brewing process. It is recommended that the 'Brew Decaf' setting be used when brewing decaffeinated coffee.
  2. Your SPEEDBREW® Coffeemaker may need to be cleaned.
Sep 02, 2011 | Keurig B50 Coffee Maker
COFFEE MACHINE KEEPS FIL;LING UP AND OVERFLOWS. tHIS IS A BUNNOMATIC MODEL STPF-15
Dunkin Donuts decaf coffee clogs the filter as the water fills the basket causing the basket to overflow. The coffee is ground too fine. Swtich brands or use a second filter to cover the coffee grounds to keep them from floating and clogging the filter.
Feb 24, 2011 | Bunn A10 Coffee Maker
Want to have a coffee using the 2nd coffee grind dispenser
no one has helped me yet. It made a half cup, but I think that may have been a fluke. The 2nd time I tried it to fill up 1 cup of decaf, it again failed. I just can't find my manual.sigh...
May 02, 2009 | Saeco Incanto Classic Espresso Machine
Magic Comfort machine won't make one cup of decaf coffee
Make sure to use pre-ground coffee only (MEDIUM
ground) and not soluble coffee.
Question- check to see where the coffee is going- did it end up in the brew group- but you did not get coffee? Then, the filter is clogged. Clean the filter. If you have used oily beans, they can clog filter easily.
Jun 19, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
