Where can i buy a belt and a cartridge for a BEOGRAM 3000? Thanks!
    Top Expert:
  • Office Equip... Master
  • 8,376 Answers
Beogram 1100 not turning
If your platter runs off of a belt then the belt would need to be replaced after many years especially if its been in storage. Another thing is, if you can see the motor with the flywheel on it, it is a good idea to spray just a little WD-40 down the shaft to free up the motor and just let it run for several hours after the table was sitting dormant for so long.
Apr 26, 2014 | Audio Players & Recorders
I have a Bang&Olufsen Beogram
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Jul 08, 2008 | Audio Players & Recorders
Cartridge failed,
Typical HP Printer Problem. Usually if you could buy replacement parts (HP Stopped selling them for all HP inkjet Printers) you could fix this. My recommendation is to buy a new "$40.00-$50.00" low cost printer Lexmark, Epson etc. and when the ink runs out Throw it away and buy a new one when you need to print again. I found that the low dollar printers print, by way far, better pictures, graphics and everything else. If you print a lot of text then a LaserJet Printer is best value. you can replace the Toner Cartridge and get 3000 pages per Cartridge. Buy a HP Laserjet if you do. everything else is not as durable. Thanks, Keith
May 18, 2012 | HP PhotoSmart Office Equipment & Supplies
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
My beogram cd 50 is not working - it will not read the disc and the door just opens. Is there another cd player that can connect to the beogram 5500 system?
YES THE BEOGRAM CD5500/6500/7000. ALSO ANY CD WILL WORK THROUGH THE CD CONNECTION JUST USE A 2 PHONO TO 5 PIN DIN PLUG ADAPTOR,NO R/C OPERATION IS POSSIBLE UNLESS YOU USE A B&O PRODUCT.
Jan 15, 2010 | Audio Players & Recorders
Disintigrating belt that moves the tray of ink cartridges on prin
Yes, it's definitely cheaper to buy a new printer.
A new printer will come with a CD-ROM, containing the necessary instructions and software for use with the new printer.
Before you connect the new printer, insert the CD-ROM, and it should "guide" you through the whole "install" process.
Dec 08, 2009 | HP DeskJet 895cse InkJet Printer
Belt drive replacement B&O Beogram 1000, type 5203 turntable
length approx 30mm shorter than old one, knock out pin on shaft to take platter off.more often than not the motor runs slow after repair,if its a round style ac motor htey cant be fixed.
May 09, 2009 | Philips gemini TT-02 MK2 Turntable
knock pin out.make sure idler assy moves freely away from motor shaft.
Where can I buy an optical reader for my cd player?
cd mech no longer available.try cleaning laser lens.try replacing 30tr6108 and30c2103 bc338 and33/16v
Feb 12, 2009 | Bang and Olufsen Audio Players & Recorders
Beogram 1800 wont play the record!!
possibly some kind of obstruction inside.
I had something similar with my turntable, and it had a dirt dauber nest inside it!
no kidding.
Dec 03, 2008 | Audio Players & Recorders
k24674
jasbo
jasbo
