Question about HP LaserJet 4 plus Printer
HP Laser Jer 4 M plus
My HP Laser jet 4m plus will print a test page off line. However, it will not print on line. I have downloaded new software and still nothing. Can someone help me?
By "on-line" do you mean it is connected to a network, and you print to it as a network printer? If so, check the IP address in the printer menu. If it is not a valid address for your router, then you won't be able to print to it.
Posted on Jan 11, 2008
  • 417 Answers
How is the machine connected? try changing the data cable if this doesn't work then shutdown your computer while the machine is on and reboot as if it is connected via LPT port some systems like to have the printer on before the computer.
Try this and I hope it helps if it doesn't then you might have a faulty print formatter board.
Thanks J
Posted on Jan 06, 2008
How to take a self test page with out computer any advances solution
The service manual shows no way to print test page without a computer attached.
Nov 22, 2016 | HP LaserJet Office Equipment & Supplies
Hp laser jet 4 plus prints only half the page then black pages then the other half with cryptic writing on pages over text
What I would do, is go out the www.hp.com/#support.
Download the latest drivers.
Install them and start printing again.
If it fails again, print a config page. If that prints correctly, that tells you that the printer is working correctly. Problem is with the interface. If you are using the parallel interface, try a different cable.
If you are using the jet direct try a different one and a different cable.
Could also be a bad formatter.
Good luck
Feb 18, 2011 | HP LaserJet 4 plus Printer
I have a laserjet 4m plus and the print is ok but the page has a grey shadow on it. Any solution? Michael D Neal
This is a sign of a worn or faulty toner drum or a dirty fuser roller.
Clean the fuser roller, switch the laser off and let it cool down first and clean the fuser roller with a cloth with a some white spirit.
If the fuser roller is clean the the toner cartridge needs to be replaced (it contains the photo drum).
Nov 17, 2009 | HP LaserJet 4m plus Printer
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
HP Laserjet 4M Plus
That sounds like a problem with your printer driver to me. If the wrong driver is used, then print codes that the other device uses will not be interpreted correctly by your Laserjet 4M Plus, which will cause it to beep. Check the driver on your computer to make sure that you are using one designed for any of the following:
HP Laserjet 4
HP Laserjet 4+
HP Laserjet 4M
HP Laserjet 4M Plus
(Either the symbol "+" or the word "Plus" may be used but most commonly the + is the non-Postscript version and the word is used with the Postscript version. Just as an FYI, the only two differences between the M and non-M versions are the ability to speak Appletalk and the addition of the Postscript module, which is in one of the RAM expansion slots.)
Mar 29, 2009 | HP LaserJet 4 plus Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Laser Jet 4 plus can't print with USB?
1.check the cable compatibility
2.install the driver HP laser jetIII
Sep 05, 2008 | HP LaserJet 4 plus Printer
Hp laserjet 4m plus
tray HP laser jet III driver
Apr 26, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
80 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
