I have a 091-320 error code. From what I learn, I need to replace black charge corona wire. Anyone knows how to do this?
4 Suggested Answers
  • 215 Answers
SOURCE: blank copy
the charge corona assy. is just the silver assembly that the corona wire is inside of. to help verify where your problem is, lift up your top lid and make a "sky" shot. watch your lamp under glass, and when lamp gets about 5-7" from left, quickly open front door. now, open the copier to inspect the bottom side of your drum. if you see a good coating of toner on drum, but not on paper, the problem is in the corona assembly thats on the bottom, middle of copier directly under your drum. if no toner on drum, then its very possible its the charge corona assy. on top of your drum.
hth,
razors
Posted on Apr 14, 2009
SOURCE: I have a HP LaserJet 2100M. It has developed a 1"
Replace Fuser Assembly check rs printer part for hp 22100 fuser Assembly
Posted on Jan 21, 2011
Ezrahite
  • 2632 Answers
SOURCE: I have an Aficio 1085
Welcome to Fixya. That mean that you have problem with the charge corona, when you open the front door it has one black wheel, under the wheel has a black oblong(the corona) from which come out a wire which is connected near, so when you will locate that part(the corona) you will see that the part is attached to metal plate with one bolt under, so unscrew the bolt and pull the corona towards you but carefully and straight to not damage the drum when you will pull out the corona you will see that inside has two or one string wire, see do the wire is broken if is broken it will need to be replaced, if the wire is not broken you will see do the part(corona is dirty if it is , clean it up with clean cloth or if you have on hand put some pure alcohol 96% on the clothe and clean it up after that insert the part(corona) inside. you can't make mistake on the path where you need to return it has a rails on both sides if you do not set the corona on the rails it will do not enter, do not use to much force if do not want to enter try again. after you will place in it place don't forget to attach the connect the wire and screw the bolt. When you will do this turn the machine on again and see do will the SC 301 disappear, if do not disappear you will need to call service because some part need to be replaced.
Thanks
Posted on May 16, 2011
Como puedo solucionar el error 091-320 en una docucolor 242de xerox
Black Charge Corona Wire is broken, replace the Black Charge Corona Wire
Sep 03, 2014 | Xerox DocuColor 242-252-260 PS
I have ricoh mpc6000 there is error code 300 how to solve
SC300 D Drum charge corona wire error: K
The output of the charge corona wire of the black PCU is abnormal. • CGB power pack connection loose, broken defective
• Check CGB power pack connection to BCU
• CGB power pack defective
• BCU defective
• Replace OPC drum More likely needs a new Charge assy. or Charge grid. Roughly $20-$100 for part(s).
Apr 29, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
SAVIN 2055 WITH AN SC301 CODE
SC301 error code description:
Charge Corona Output Error 2
Charge Current Leak
Charge would need to change number of pieces corona wire A166 9516 (to confirm with the service repair center) Charge Corona Wire.
Hope helps (remember to rate this)
Sep 30, 2010 | Savin Office Equipment & Supplies
SC387 error code on Ricoh
SC387 Drum potential
error
Cause
· Uneven charge
· Worn drum
· Defective potential
sensor
Try the following
1. Clean the charge corona unit or replace the charge
corona wire and grid plate.
2. Reinstall the drum.
3. Replace the drum if necessary.
4. Replace the potential sensor.
Let me know if you need any more assistance
May 08, 2010 | Ricoh Aficio Colour 3006 Color Copier
C0200
Corona wires are used in the transfer/sep assy and drum charge. C0200 is code if they fault. To reset the machine open and close the front door, if ithe code comes back the corona wires and or assy need replacement
Feb 19, 2010 | Konica Minolta DiALTA CF910 Copier
I have Ricoh Afisio Copier and I have error code SC301
That mean that you have problem with the charge corona, i'm not sure for which model do you talk about but it should be when you open the front door it has one black wheel, under the wheel has a black oblong(the corona) from which come out a wire which is connected near, so when you will locate that part(the corona) you will see that the part is attached to metal plate with one bolt under, so unscrew the bolt and pull the corona towards you but carefully and straight to not damage the drum when you will pull out the corona you will see that inside has two or one string wire, see do the wire is broken if is broken it will need to be replaced, if the wire is not broken you will see do the part(corona is dirty if it is , clean it up with clean cloth or if you have on hand put some pure alcohol 96% on the clothe and clean it up after that insert the part(corona) inside. you can't make mistake on the path where you need to return it has a rails on both sides if you do not set the corona on the rails it will do not enter, do not use to much force if do not want to enter try again. after you will place in it place don't forget to attach the connect the wire and screw the bolt. When you will do this turn the machine on again and see do will the SC 301 disappear, if do not disappear you will need to call service because some part need to be replaced.
Please rate the post if was helpful for you for i to know does this was helpful or not for to know to post some more information
Jan 11, 2010 | Office Equipment & Supplies
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
Black partial fading
It's either the opc drum is on it's way out or the charge roller/corona wire faulty or needs cleaning
May 18, 2008 | Samsung CLP 300 Laser Printer
Panasonic 7735 problem
did you tried to restart the copy machine or to disconnect it from electricity for few minutes?
Jul 15, 2007 | Panasonic FP-7735 Black and White Copier
27 people viewed this question
jasbo
jasbo
