Tv audio settings
Tv's operating instructions
Without a remote, how can I change language from English to Spanish?
How Do I Set New Preferences with My Blu-Ray Remote ...
www.ebay.com > ... > DVD & Blu-ray Players
To reset your Blu-ray player to its factory settings, you cannot use a remote. ... Press 1 on your remote for English, 2 for Spanish, or 3 or French. ... If subtitles are notavailable in the language you selected, they will simply disappear during ...
How do I adjust subtitles, captions and alternate audio on ...
https://help.netflix.com/en/node/372
NetflixAlternate audio changes the language of the content you stream or changes your audio to 5.1 surround sound. ... To save or adjust your subtitles and captions settings, play a TV show or movie ... TV and iOS devices must be done on the actual device, not the website. .... Most Blu-ray players, Smart TVs, and Set-top boxes.
[PDF]Operating Instructions Blu-ray Disc Player DMP-BD655 ...
ftp://ftp.panasonic.com/bluray/om/dmp-bd45_mul_om.pdf
Panasonic
Dec 21, 2015 | Televison & Video
How do i connect my jvc camcorder to my lg recorder
These instructions should be very similar to hooking up to your lg recorder Hope this helps
Instructions
    • 1 Plug the white and red audio cables into the left and right Audio OUT ports on the back panel of the DVD player. The ports should be color-coded white and red as well, but if not, connecticon1.png the white plug to the left audio and the red to the right.
    • 2 Connect the yellow plug to the Videoicon1.png OUT port on the DVD player.
    • 3
    • Plug the other ends of the three cables into the matching composite AV IN jacks on the back of the JVC LCD TVicon1.png.
    • 4 Turn on the DVD player and the JVC set, then press and release the "Input" button repeatedly on the TV remote control until the DVD screen appears on the LCD panel.
Read more: http://www.ehow.com/how_6647268_hook-player-jvc-lcd-tv.html#ixzz303ZGkASL
Apr 26, 2014 | Computers & Internet
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
How to disable audio description on LG 32LH3000
First of all, thank you very much George for choosing FIXYA today for your online technical support needs.
See page 136 of the User's Manual for detailed instructions and illustrations on how to disable the AUDIO DESCRIPTION feature on your TV set.
Basically to disable it just press the MENU button on the remote.
Then use the arrow keys to select the AUDIO option.
Then select the AUDIO DESCRIPTION option.
Then use the up / down arrows to toggle the setting to OFF.
Then just exit the MENU.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.lg.com/uk/common/product/support.jsp?localeCd=uk&productId=32LH3000&uri=/uk/tv-audio-video/televisions/LG-lcd-tv-32LH3000.jsp#
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above. Then select OPEN FILE when prompted.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Jan 16, 2012 | LG 32LH3000 32" HDTV-Ready LCD TV
I need instructions for hooking my VCR to my TV set,
using a scart cable, connect the tv socket on the vcr to the scart - in socket on the tv.
good luck.
May 10, 2011 | Philips Televison & Video
Audio goes off by itself & have to turn tv off then on to get audio back why
Appears that the audio volume mute functionalities have been altered to display momentarily shortly to go on silent mode. The TV settings have to be realtered to acquire default audio or volume features during functionality or operations. The type of device connected to the TV mayy simply operate mometorarily shortly least producing sound past several moments. Ascertain the devices with which the TV is acquiring audio or videography. Disconnecting to resestablish upon reconection should perform default functionalities. Refer to user guides for diagnostic performance of TV during operations. Consul technical experts thereafter. Good luck
Jan 08, 2011 | Vizio 42 in. LCD TV
How come my new Samsung NDTV bought from Singapore has no sound when cable antenna is connected? but there is sound when connected to play Dvd.
The Audio is not set to the frequency available in th cable TV. so first check out from your cable operator the correct audio frequency - can be B/G,5 Mhz, 5.5 Mhz or even 6 Mhz.
Choose the audio settings inthe menu and set the TV to the new properties and then do an auto scan.
If not ask your cable operator for a digital box and connect the composite audio and video( RCA out) to the AV of the TV.
This will work out.
Aug 30, 2010 | Samsung LN-T3253H 32 in. LCD Television
I have a dvd player drc212 that i have no
Hi Tana,
If your TV is supplied with a video input, you will need a set of Composite Baseband video cables commonly known as RCA cables (Yellow, Red, White).
See the last paragraph if your TV is not supplied with a video input.
You will connect the Yellow (Video) from the DVD's video output, to the Yellow (Video) input on the TV set; example is VIDEO 1 or AV1.
You will connect the Red (Right Audio) from the DVD's Red Audio output, to the Red (Right Audio) input on the TV set using the same input number as example above.
You will connect the White (Left Audio) from the DVD's White Audio output, to the White (Left Audio) input on the TV set using the same input number as example above.
Turn on DVD, and TV set. Select the proper input on the TV set using the input button (video, source, AV select, etc.)
If your TV set is not supplied with a video input only a coax cable input, you will need an RF Modulator which can be purchased at any Best Buy, Radio Shack, Wal-mart, etc. You will also need a small coax jumper (3 to 6 foot should do it), and a set of RCA cables (Yellow, Red, White) as described above. The RF Modulator comes with instructions on how to connect it. It has a coax input, RCA input and a coax output that will connect to your TV set.
I hope this helps. Cheers.
Feb 09, 2010 | Televison & Video
Need instructions to set up Cyberhome DVD 1200 player
Useing RCA cables -(yellow video out) on the dvd go's to yellow video in on the tv. Then (red -right) out on dvd go's to red audio in on the tv . And white-left out on dvd go's to white-left audio in on the tv! and thats it
Dec 24, 2008 | Cyberhome Televison & Video
I have a jvc TH-S51 and i cant seem to get the surround sound to work with the tv can anyone help?
Connect the surround to the TV, using RCA cables and following the manual instructions.
Once connected go to settings menu on the TV and chose audio settings.
Set the audio settings to the one needed from your surround.
Sep 07, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
