Question about GE Televison & Video
I have an older GE Stereo Monitor with no remote. All of a sudden it's all snow. I need to set it on channel 3 to work with my cable. However, the channels only go from 49 to 68. Any help?
    Top Expert:
  • GE Master
  • 74,999 Answers
Without a remote control, you can't select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
If you wish to get further advice over phone; visit
Posted on Dec 08, 2016
How do i reset the factory volume level on a ge remote monitor xs stereo without the remote?
[PDF]CARESCAPE™ V100 Vital Signs Monitor - GE Healthcare
GE HealthcareNov 21, 2011 - NOTE: The information in this manual applies to CARESCAPE V100 Vital Signs Monitor ...... PULSE VOLUME indicator: flashes to indicate you are making a change to ...... monitor is set to or reverts to factory default settings.
Nov 23, 2015 | GE Televison & Video
How do you install a sabrent vga converter?
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the back of TV-LCDHR. Plug in the power supply. You should now see a red light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on your Cable TV service. When it's done, use the remote to change channels and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality, we recommend using a pair of amplified stereo speakers. Connect them to the "Audio-Out" port on the side of TV-LCDHR.
Aug 17, 2011 | Sabrent TV-PC85 PC to TV Converter Box
Was just given a 1995 RCA Remote Monitor XS Stereo Colortrak TV. Seems to work fine, but remote doesn't. Can change channels manually, but after about Channel 5, it skips most on the way up to 99. How...
Just about any One For All remote control will work with this unit and any other remote controlled devices you may have.
This sounds like when doing the channel scan the scan was interrupted and therefore went from the channels it had already found to the ones that were at the high end of the register. Also, when you are in the setting menu, you need to specify the input as either cable or antenna, preferably cable, which will also scan each channel from 2 through 125. Please let me know if there is more information you would like and I hope you have found this helpful.
Jul 01, 2011 | Televison & Video
How do I put the GE remote xs stereo monitor into input mode without the remote?
A good universal remote to use with that monitor is the RCA RCRN04GR, available at WalMart. I recently bought a 25" GE Remote Monitor XS Stereo from a Days Inn that was replacing all of those monitors with Flat Screen TV's. When I got it home I found that it would not go to channel 4 which was default with my COX Digital Cable Box. Channel 3 is the default channel on the monitor, so I ran an AV cable from the cable box, disconected the coax and hooked up the AV cable to the back of the TV and that solved the problem. I hope that answer was helpful.
May 31, 2010 | GE Televison & Video
Suddenly SNOW on all channels
your tuner has failed;
time for another set the cost to repair is too high
May 29, 2009 | Televison & Video
3 of five local channels went to snow
are there any lightnings or thunder in your area when it happened.try checking your tuning settings,maybe the program was reset so u need to reprogram the channels again.try removing the batteries of your remote and put it back on again then try to access.i have encountered that problem and i end up buying a new
tuner module.and that fixed the problem.
Jan 28, 2009 | Philips 20PS40S 20" TV
Switching Input on GE Stereo Monitor
I tried for a while to get my dvd to work. I went to the menu, from my universal remote that totally works. Went to the menu, then channel set up, and switched the VCR1 channel to 00Enabled. When I want to watch a dvd I press 00 for my chanel and it works. I hope this helps all of you.
Dec 13, 2008 | Televison & Video
Unusable Signal for PS2
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
May 13, 2008 | Televison & Video
Symphonic SC3919
most likely your channels are in SAP mode, you need to set them up as stereo via the menu. Remote code should be 044. For VCR. turn TV to channel 2 or 3 then press VCR button
Sep 11, 2007 | Symphonic SC3913 13 in. Combo
Televison & Video Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
