Question about Cameras
My Jensen smps-650 wont turn on the charging light stays solid red when plugged in. When unplugged from charge the unit wont turn on. When plugged in green light flashes dim an turns red
SOURCE: i cant recharge my battery
I have the Jazz DV179 and have the same problem, there was nos no a/c jack when we had purchased it and now it is died and will not charge, I have even tried to charge through the computer and still it is not charging, does anyone have any idea on how to charge this:?
Posted on Oct 07, 2008
SOURCE: Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
Posted on Apr 06, 2009
  • 259 Answers
SOURCE: no sound
it sounds like the battery is crook hope this helps regards Jim
Posted on Apr 17, 2009
SOURCE: controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Posted on Jul 02, 2009
  • 7 Answers
SOURCE: My Casio Exilim EX-S880 wont turn on. Battery is
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
Vibe bluetooth earbuds wont charge
That's a shame. However, this query is more for a forum dealing with audio equipment - this forum is for Cameras.
Sep 18, 2017 | Cameras
Can't get my iPhone to Pair with new Jensen SMPS-650
Hold botton down until it flashes blue AND then red it will continue To flash now pair ur headset
Dec 09, 2012 | Jensen Bluetooth Wireless Stereo Speaker...
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
When I plug in the ac adaptor to charge unit,the instructions state the chg light will go off when charged. Is it possible that it is charged and the light stays on. I charged it (in the off position)...
The unit still,work?The battery when it low,the battery light turn yellow or red?Than when it fully charge it turn green?Just unplug the unit and use it dosen't matter,if the light don't turn off the light,that find.Or the battery is old and not taking full charged anymore that another resoan the charging light still on.
Jun 14, 2010 | Mintek MDP-1770 Portable DVD Player
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
When I turn on my N64 with everything plugged, the red light wont turn on!
What's the RED light For ? usually indicates charging ..if flashing if steady then it's fully charge to a GREEN light unless it's already Solid RED
Sep 18, 2009 | Video Game Consoles & Games
Headset will not turn on
hello to you, ahh yes the wonderful world of moto, it sounds to me like your not letting it charge long enough, when you start the charge it will go red, than after a bit it will go yellow and when fully charged it will go to a real dark green.( some times up to 3 hours, no!! im not kidding,) it amazes me how long it takes. step 2. when you want to put it in discover mode press the call button in till it turns solid purple than pull the mike down real quick and it should stay purple at this point you have 30 seconds to pair that puppy. good luck and you will get used to it. hope you only have one. i have seven.
Jan 27, 2009 | Motorola Mobility H700 Wireless Headset
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
I cant recharge my battery
i just bought the cam can you tell me how long it takes to charge the battery . i have had it on charge overnight and i stiil have a red light the cam works when it is pluggedn in but as soon as i unplug it nothing works. the reading on the camera is saying that the battery is full
Jul 25, 2008 | Jazz DV-179 Digital Camera
Jazz DV-179
Jul 12, 2008 | Jazz DV-179 Digital Camera
Cameras Logo
43 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
