Question about Horizon Exercise & Fitness
Horizon T74 Treadmill powers on, programs and incline work, belt does not move and no sound from motor. What do I check?
    Novelist:
  • 145 Answers
Hi there, ....Sounds like a lower board issue. You can contact jatinahATrocketmailDOTcom for repairs on this style of unit. Good Luck!
Posted on Jan 03, 2017
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 06, 2016 | Horizon Fitness Exercise & Fitness
Stuck in up position. Bought a new incline more and if it goes above 5, it will keep climbing and won't come down.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 24, 2016 | Horizon T61 Treadmill
Horizon Elite 5.3 treadmill blows JP2 fuse. Incline does not work, all other functions work even with fuse blown. Does not blow if I disconnect incline motor.
Great work! Another great point for treadmill servicers! Please be aware....inside a treadmill lift motor, there is a small potentiometer or pot, that watches the "throw" or position of the lift screw, which relates to the treadmill incline. These lift motors have a sheath or "nut" on the screw that MUST be set properly at the ZERO degree mark of the deck, for proper operation from zero elevation to 12% or whatever it's uppermost incline is. This must be assembled correctly, or like in this case, that motor begins to "pinch" at one end of it's "throw" and the current will rise in the winding and blow a fuse, saving the lift from burning up. Nice job troubleshooting Thad!
Feb 05, 2016 | Horizon Exercise & Fitness
What is causing my Treadmill T202 to display a "connection" and make a loud beeping sound?
you should remove the motor cover and inspect to see if you can locate where is came from. check the incline motor
Aug 09, 2014 | Horizon T202 Treadmill
Why does power on but treadmill doesn't move?
DEAR
IF YOU LISTEN SOUND OF RELAY AFTER START YOU FORGET SET MOTOR WIRE IN OTHER WISE YOUR MOTOR CONTROL BOARD IS DAMAGE
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 31, 2017 | Horizon Elite 1.2T Treadmill Walking Belt
Horizon treadmill won't incline
Step 1:
see the diagram attached.
Clean the motor, lube the gear+shaft
Adjust the small POT for a little.
RUN the software calibration for troubleshooting. see the diagram
Step 2:
Step 3:
Step 4:
he Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Feb 07, 2013 | Horizon Fitness Horizon T101 9 Program...
I have a horizon t73. Best treadmill ever but it now wont start. It turns on, electrical works, sounds like it going to run but the belt doesnt move. any ideas?
Dear Sir:
1) Tight the deck belt see the diagram 2) Lube the deck belt in according with the instruction manual maintenance. 3) Test the drive belt and replace it 4) Measure the input voltage for the main motor if there are the motor need repair or replace 5) Test the output voltage from the main motor board if there are NOT the board is faulty.
Apr 29, 2012 | Horizon Fitness T73 Treadmill - $1,299...
My T81 treadmill quit working. All of the lights and bells and whistles all work but the belt doesnt move and the incline doesnt move. Ive only had it for about 2 years. It was working fine before I moved...
you need to check voltage going to the motors. no power ,the contoller board is not working. check the connections on the boardmake sure they are in all the way,also the power connections
Mar 17, 2011 | Horizon T91 Treadmill
Manual Treadmills vs. Motorized Treadmills
Treadmills come in two basic varieties, just like lawnmowers: manual and motorized. But, unlike a lawnmower, you will generally get a better workout from a motorized treadmill. Manual Treadmills - Getting Going On a manual treadmill, the action of your feet against the deck moves the belt. Pros * You provide all of the motive power and exercise your lower body. Cons * It can be difficult to get the belt moving intially. That straining against the belt can stress your joints. * You may have to raise the incline of the treadmill significantly to make it easy enough to get the belt moving. * Once the belt is moving, however, you would have to stop and get off to change the incline, so you are stuck with one incline level during each workout. Motorized Treadmill Advantages * The belt is moved by the motor, you don't have to strain to start it. * On many treadmills, you can adjust the speed and incline while you are still walking or running. On others, you may have to get off and adjust the incline manually, but you just have to turn on the treadmill to start the belt again. Manual Treadmills - Speed With a manual treadmill, you go only as fast as you push yourself. If you slow, it slows. If you stop, it stops. Motorized Treadmill Speed and Workouts The speed is adjustable and many motorized treadmills have workout programs that adjust the speed to give you a varied workout. This pushes you to go faster. The constantly moving belt of a motorized treadmill motivates you to keep up. Costs Manual treadmills are relatively inexpensive, in the $100-200 US range. Motorized treadmills for home use cost from $750-$5000, and generally the more you pay, the better you get. Most motorized treadmills under $1000 have underpowered motors and are less sturdy and have fewer options for adjusting the incline, programmed workouts, etc.
Dec 01, 2008 | Endurance TF3i Folding Treadmill
Exercise & Fitness Logo
109 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
