The words o select cycle are not coming on. - Office Equipment & Supplies
I cant open my microsoft word,because the dialog box are open
hold down ALT and press TAB in Windows see if there is any Word question BOX windows open in a minimized window . That is what it means by a dialog box being open.
HOLD down ALT and press TAB , Press TAB , Press Tab and it will cycle through each window that is opened in windows.
If this does not work then PRESS CNTR - ALT - DEL together in this order and then select Task manager when the blue screen appears.
Then select word from either the applications listed or from the processes listed and end task.
May 29, 2017 | Microsoft Computers & Internet
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
How do i download a microsoft word software for my computer
Microsoft Word comes in bundle with other software. This software suite is called Microsoft Office that has different versions like Office 2003,Office 2007 etc. When you download Microsoft Office, during installation you can select Custom Installation and select MS Word and do not select other softwares. You can get the trial version of MS Office from the following link. http://www.brothersoft.com/microsoft-office-60484.html
Apr 05, 2011 | Acer Computers & Internet
When I print something out, ink-less lines interfere with what I'm trying to print. For example, if I were to print an essay, a line cuts through a sentence so that the line of words and letters is...
Sounds like a clogged print head. Have you tried cleaning the print heads?
From your printer's setup page, click on the "Maintenance" tab and select "Deep Cleaning". Then click on "Execute." When the confirmation window comes up, click on "OK". The cleaning cycle starts when the power lamp begins to blink.
Don't try doing anything else with the printer until the cleaning cycle is done...it takes about a minute.
Hope that's helpful.
Jan 14, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
The words Sud comes up in the rinse cycle. What does this mean?
You are putting too much soap before you begin the wash cycle...... When the word SUDS is displayed then on the rinse cycle there is too much soap and the suds are still on the clothes. Try cutting back on the soap, maybe cut back almost 1/2.
Jul 12, 2010 | Kenmore HE2 Plus Front Load Washer
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
The cleaning function doesn't work (Frigidaire FEF377CFBD). When I push the control for cleaning the word clean comes up and a time section appears to select how long. After 5 - 10 seconds it starts...
It could very well be a bad control board which is very common now days due to overheated and burnt out capacitors. You can test any capacitor with an ohmmeter in the ohm setting. You can test power to any device or component with a voltmeter. Or you can get a multi-tester with ohm and volt meters
Oct 13, 2009 | Kitchen Ranges
This is a heating and cooling through the wall heat pump. It works normally when heating is selected - the heat pump runs and both speeds of the fan blow warm air. But nothing runs when cooling is...
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Jul 21, 2009 | Heating & Cooling
The word "suds"
to much detergent...with theses unit you must use he or low suddsing detergent..take half the wet soapy clothes out then start unit..sud level must fall...
Dec 27, 2008 | Maytag MAH8700A Front Load Washer
22 people viewed this question
k24674
jasbo
jasbo
