Question about Dryers
Amanda dryer will turn on but no heat comes out. Sometimes if you wiggle the timer knob it will heat and later quit.
    Top Expert:
  • Dryers Master
  • 34,089 Answers
Defective heating element or timer
Posted on Dec 08, 2016
muttandjeff
  • 359 Answers
SOURCE: kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Posted on Dec 23, 2008
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
SOURCE: my whirlpool imperial seventy dryer
I have the same dryer and it did the same thing to me. It ended up being the thermal switch and a frozen drum and belt due to excessive lint. Had to pay $190 to fix it, not sure if this is something that can be self repaired.
Posted on Feb 01, 2009
aborcass
  • 2651 Answers
SOURCE: MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Posted on Mar 20, 2009
aasc
  • 1606 Answers
SOURCE: GE Dryer timer doesn't work
Replace the timer . If model number given , could give the part number .
Posted on Aug 09, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Timer does not tick and dryer does not reverse direction
The timer not moving is a sure sign it needs replaced. Fortunately replacing it is easy. Just search for your make and model dryer and order the timer. Remove the power, the back panel with the timer, the knob on the timer, and just a couple of screws and it's out. One by one move wires from old timer to new, install the reverse as taking it out. Put the knob back on, and the back panel. Plug it in, and you should be golden.
Ah, I just saw you answered in your own question! Good job! :-)
Anytime the drum turns, with or without heat, and the timer makes noises, doesn't move, has to be wiggled to start, or the start position changed, you can bet it's the timer. We just don't want to take a risk because it's one of the most expensive parts to replace, usually the motor costs a bit more, but seldom go out. Don't waste time troubleshooting other parts if any of the above applies, it's usually the timer.
Aug 30, 2015 | Dryers
LE6090XS Dryer timer open
Timer part # is 696434. But, as you already know, it is no longer available. You might try doing a ebay search for that timer.
Sep 01, 2017 | Dryers
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
Hi, I have a Kenmore Dryer Model 100.96591240. 15 years old (approx). Problem just started - I have to wiggle the Timer knob after pressing the Start button (sometimes I have to push the Start buttom and...
i took apart a dishwasher and in the timer switch there were some electrical contacts and over time they get a black burnt build up on them and need to be cleaned or replaced .might need a new switch
price one on ebay . or look at sears.com for a new part
Jan 10, 2010 | Kenmore 73952 Gas Dryer
When u turn on my gas whirlpool dryer it runs as normal. when u check on it a little later (on automatic dry) the timer has not moved, and the dryer has quit producing heat
Hi, the timer control the heating commands and, if its not moving(rotating), this will confirm timer failuer. replace it asap.
Jun 18, 2009 | Dryers
The dryer has power but the start cycle knob only buzzes
IF THIS MODEL USES THE TIMER TO START THE MACHINE BY PULLING OUT ON THE KNOB, I HAVE HAD TO REPLACE QUITE A FEW TIMERS FOR THIS PROBLEM. SOMETIMES BY MOVING THE KNOB UP AND DOWN AND SIDE TO SIDE WHILE PULLING WILL START THE MACHINE. IF SO, REPLACE TIMER.
Nov 20, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore electric dryer won't stop running / no heat! 110.62512101
Without anymore info. is sounds like the timer motor on the setting controller (the main knob) is bad. The entire timer/control part is usually pricey but if its made to where you can just change the timer motor that will be less. If possible check the timer motor with a meter for continuity to be sure. the parts supplier will usually help you with this, if they are worth a shit.
Dec 19, 2007 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
