Question about Microwave Ovens
Heard a beep then :0 appeared and the clock cant be set
We were eating dinner and hadn't used the microwave for awhile when we heard a beep from across the room. After that, we can't seem to reset or get the clock to display. Unplugged it for several hours and still got the same display :0
MicrowaveSvc
  • 9098 Answers
SOURCE: My display reads -SE-
-SE- error means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a Kitchenaid Microwave
F2 on a Kitchenaid microwave means you have a shorted keypad.
You have a failed keypad.
William E. Miller
prototech@usa.net
Posted on Aug 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Posted on Oct 21, 2008
ginko
  • 19396 Answers
SOURCE: Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Posted on Oct 24, 2008
nikeananth
  • 267 Answers
SOURCE: Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Posted on Sep 23, 2009
LG Microwave MC8289UR/00 want to know if has child lock and how to turn on and off
Here is a section of the manual for your microwave on child lock, hope this helps.
"L" - Page 7 Press and hold STOP/CLEAR until " L " appears on the display and a BEEP sound is heard. The CHILD LOCK is now set. The time will disappear on the display . To cancel CHILD LOCK press and hold STOP/CLEAR until " L " disappears. You will hear a BEEP when it's released. If any button is pressed, "L" will appear on the display Your oven has a safety feature that prevents accidental running of the oven. Once the child lock is set, you will be unable to use any functions and no cooking can take place. However your child can still open the oven door. Press STOP/CLEAR. Child Lock 7
Jan 10, 2018 | LG Microwave Ovens
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
11-30-2010 I need the user manual of Amana Mictowave model RS560W . Kindly assist. Thanks. Rgds Alon Felz The real problem: After heating the food (in a certain time selected), a beep sound should be heard...
In order to solve the problem this is what I did (with a help of Mr. Hilik
@ www.microgal.co.il)
1. Unplug the power cable 220Vac from the wall outlet.
2. Make sure or the clock led is "off" and screen is dark
3. Plug again the power cable 220Vac
4. Nothing comes "on" on the led screen
5. press on the digit "zero" (0) and you hear a beep signal
6. Take a glass filled with water press on the digits "1" and then "0" and
then "start"
7. After 10 seconds the beep signal will come on again.
8. Note: this kind a phenomena appears after voltage cut off when there
is a need to lift up again the handle on the voltage breakers . FYI.
Jan 30, 2010 | Microwave Ovens
Have a kitchenaid superba part no. 4450786A with the probe indicator beeping for a temperature to be set. Prior to beeping started just used microwave to warm food; didn't need or use probe. What is...
Put the probe in the oven and beeping stopped. Left it in overnight and next morning took the probe out and there was no beeping. Have not heard beeping all day. Don't know why this worked but it did.
LaMason
Oct 12, 2008 | Microwave Ovens
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
Microwave re-started
The Start pad on the keypad may be starting to short. If so, a new keypad (membrane switch) would fix it.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's at
http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The part # needed is A64795790AP "membrane switch" for $46.88 available here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | Microwave Ovens
Microwave Oven Panasonic NN-5560A
Chances are your Start key on your keypad has failed.
It is part # A64795790AP "MEMBRANE SWITCH", it runs $46.88 and you can find it here:
Jun 03, 2008 | Microwave Ovens
The beeps have become inaudible.
The beeper sound level can be adjusted. Press the BEEPER VOLUME button, then choose 0–3 for mute, medium or loud.
If that doesn't work, unplug the oven a few minutes, plug it back in, then try again.
If you don't have your owner's manual you can find and download one here:
http://www.geappliances.com/service_and_support/literature/
Feb 22, 2008 | GE JVM1651 Microwave Oven
It's displaying "lock" and The keypad is not responding.
1. Press "CANCEL". 2. Press and hold "0" (zero) until the word "LOCK" disappears from the display and a single beep is heard. You can download your manual here: http://tinyurl.com/vpxss
Nov 03, 2006 | Tappan TMT104E1 Microwave Oven
1. Touch the "CANCEL" pad. 2. Touch and hold the "0" (zero) pad until the word "LOCK" disappears from the display and a single beep is heard. The microwave is locked the same way. You can download a manual similar to your model here: http://tinyurl.com/vpxss
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
