Question about Pool & Spa
My aqualing is constantly offline. Contcted a tech and it seems the antenna needs to be replaced. How can I yturn the light on in the pool and jcuzzi, manually until the unit get replacedf
    Top Expert:
  • Pool & Spa Master
  • 8,688 Answers
Put into service mode but might have to set heater temp you aren't using the control temp sensor now
Posted on Nov 12, 2017
2 Suggested Answers
  • 20 Answers
SOURCE: My sirius starmate says "antenna not detected".
The antenna that needs to be replace!
http://satelliteradiofix.com
Posted on Apr 01, 2011
The remote turns on but cant select any buttons replaced the batteries and reset the pool panel
turn off remote then turn off aqualink turn aqualink back on then turn on remote if still doesn't work check 4 pin red plug inside panel at top if ok check to see if wire to antenna cut if ok open antenna and see if green and red lights are blinking
Sep 14, 2015 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Why will my digital antenna not rotate using either the remote or manual button?
If the motor has not been turned for a long time the grease on the gears may dry out and freeze the motor.
Mar 19, 2015 | Lava HD-2605 Ultra with G3 Control Box...
Will the radio not work if the power antenna was replaced with a NON powered antenna
This is defanitly your problem car has amp in trunk factory you have to hook your remote (blue white stripe) up to the power accessory wire wich will only come on when your key is turned back so use a light tester on wires to see which wire is not hot until key is on one power wire will stay on constantly dont use constant it will run the battery dead
May 04, 2014 | 1993 Lincoln Mark VIII
Antenna red light comes on when mike is keyed. Radio checked, no problems. Installed in Mack 2012 Pinnacle Dump truck
there are two lights for the antenna.when you are transmitting the top light will change from green to red the bottom shouldn't be on.this is the awi light. it means there is a problem with the antenna system, and you should get it checked. It could be the antenna swr ,bad coax,or the radio.Since you can't do anything with the coax or radio it has to be done with the antenna. Get a real SWR meter and check the SWR or have a tech do it. If the SWR is ok then your antenna just might be in the wrong spot ,or it may need to be grounded A tech will tell you the problem as soon as he puts his meter on it.
Apr 17, 2014 | Cobra 29 LTD CB Radio
Aqualing rs4 random colors pool spa
go into system set up lights highlight your lights save then turn everything offf then back on they should sync
Apr 12, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Just replaced fuel pump now rear lights are goofy. If the engine is off the rear turn signals work fine but no running lights. With engine on, the left turn signal causes both lights to blink rapidly with...
YOU HAVE A BAD GROUND FOR FLASHERS OR FRONT YTURN IS OUT AND RUNNING LITES HAVE FUSE GOOD LUCK LOOK AROUND FUEL TANK FOR TORN OR PINCHED WIRES
Oct 06, 2011 | 1998 GMC Sierra
Need the color code for stereo the speakers power seems to be hooked up to my dash lights dimmer switch 1991 jeep cherokee limited
Here you go;
1991-92 Jeep Cherokee Stereo Wiring
Constant 12V+ Red/White
Switched 12V+ Purple/White
Ground Black
Illumination Blue/Red
Dimmer Red/Black
Antenna Trigger Purple/Orange
Antenna Right Front
Front Speakers 5 1/4" Doors
Left Front (+) Gray
Left Front (-) Yellow
Right Front (+) White/Red
Right Front (-) Brown/Red
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Gray/White
Left Rear (-) Brown/White
Right Rear (+) White/Black
Right Rear (-) Brown
Mar 16, 2011 | Jeep Cherokee Cars & Trucks
No power to Rayvak heater
You have a bad transformer. Probably shorted out from the mice eating the wiring.
Aug 07, 2009 | Raypak Harness Wire, Mv
Error code CE on hayrwrd pool heater h series
This is the 3rd time I have had this same problem. First two times they replaced all the circuit boards under warranty. It seems as if there is an inherrent design flaw with this heater. Reseating cables on both of the last two times seemed to fix the issue. However the tech replaced the boards anyway.
Apr 12, 2009 | Hayward H Series Pool & Spa Heater 400k...
Have been trying to install several different wifi external antennas - Engenius, Linksys, a "home-made" one. Problem with all of them is the same - the hardware is recognised, but the signal remains the...
ok i gotcha here its not any of the antennas its your service provider some reason you havent been recognized by your service provider you dont have a good ip yet
the way to tell you mentioned your self you tried different antennas the comp recognizess them but still no signal you need a satelite signal for what your looking to do being on a small island
also make sure your internet is not running offline on your internet page it will show in tools if your running online or showing offline
Dec 06, 2008 | SENAO High Power 200mW USB WiFi 802.11bg...
Pool & Spa Logo
100 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
