Question about Premier Kitchen Ranges
Looking for a manual on how to install a spark module in a Premier Gas Range oven ModelP36s148BP
catriver
  • 878 Answers
SOURCE: STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
Posted on Sep 07, 2006
catriver
  • 878 Answers
SOURCE: Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
SOURCE: recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
Posted on Mar 28, 2009
SOURCE: Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Posted on Jul 28, 2009
SOURCE: No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Posted on Nov 24, 2011
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
OVEN ignition starts ok then after severl seconds the gas is turned off.\r\n Also range burners tend to continue sparking. Using Propane -- poor quality.
ignition level is low (it should be not less than 3.1 A) if it's below gas will turn on and off. you need to replace ignitors.
sparking is automatic reignition control (spark module), try to clean burners first and make sure they installed properly back after cleaning., if not than replace spark module.
appliancesrepairla.com
Jun 22, 2010 | Viking VGIC485-6G Gas Kitchen Range
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Premier 30 inch gas stove oven does not light
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
Oct 28, 2008 | Premier P36S318BP Gas Kitchen Range
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Viking 4 burner gas range
if you are not hearing the faintest sound of clicking / sparking you could have a bad spark module or even bad burner switches i doubt that all switches went bad at the same time but its possible unplug oven check wireing to switches and spark module if you pull your burner knob off thats the switch starring at you follow wires and check for any loose connections
Dec 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GAS RANGE OVEN CAN'T SEE THE MODEL ON THIS SITE JPBC????
Sounds like the sparker in the oven isn't correctly installed, if you hear gas try and light it with a lighter, (WATCH OUT FOR YOUR FACE)
Aug 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Roper Gas Range
F1 Error
Mar 24, 2007 | Roper FGP305 Gas Kitchen Range
Kitchen Ranges Logo
59 people viewed this question
Top Premier Kitchen Ranges Experts
Paul Carew
ray gallant
Terry
Terry
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
