Question about Honeywell Heating & Cooling
I need a wiring diagram for Honeywell R8184G protecto relay
4 Suggested Answers
  • 540 Answers
SOURCE: wiring diagram
C--=common r-red=power y-yellow=cool g-green=fan w-white=heat..!
Posted on Sep 09, 2008
SOURCE: Wiring Diagram for Honeywell ST9103A1002 needed
Are you still in need of this
Posted on Oct 21, 2008
  • 588 Answers
SOURCE: i need a y plan wiring diagram
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on May 12, 2010
I need a wiring diagram for a thermostat
the new honeywell should have a wiring diagram with it.
Jan 28, 2016 | Honeywell Heating & Cooling
How do I change out a R4184 D 1027 to a R8184G protectorelay oil primary
the primary difference between them is the 4184D seems to use a line volt thermostat you would need to jump the thermostat leads on the r8184g and set the line volt thermostat in series with the power load side of the incoming power check the link for a diagram from Honeywell. good luck
Dec 14, 2014 | Honeywell "R8184G4074 Oil Burner Control,...
Old primary relay can't find part number
sounds like the flame recognition is not sensing a flame.. some models use a rod that gets corroded.. a little cleaning with fine steel wool and a vinegar bath, rinsed with water and dried works well to clean up the rod..
Jan 03, 2014 | Honeywell Heating & Cooling
Wiring a Honeywell V8043E for two zones
Honeywell posts pdf manuals.
Google seArch Honeywell V8043E .pdf
Include .pdf in search parameter to find manual with wiring diagrams.
Oct 26, 2012 | Honeywell V8043E1012 Zone Valve 3/4 Sweat,...
I need the wiring diagram for this thermostat, there are four wires that are hooked up red,white,blue for yellow and green. They connect to a honeywell relay that has five connection, y,g,w,c,and r, do i...
On the fan relay hook up the red to r terminal the white to the w terminal and the green to the g terminal , now the blue needs to hook up to one of the two wires going to the outside condenser unit and the other going there goes on the c terminal . The blue does not have to go on the honeywell rrelay just wire nut it to the wire.
May 13, 2011 | Carrier TSTATHCP Programmable Thermostat...
The instructions say the Honeywell DT92E needs only a two wire connection, but the wiring diagram shows three, which is correct Please
This Honeywell control thermostat is made for wireless control, by means of a relay control transmitter with a range of 30 meters. It only needs a 2 wire connection on this stat if indeed it is the DT92E stat. Even though the diagram shows three, you will need only 2 for operation. This is a fact. I have done some reading on this model and many of its relatives, so with built in relays, and transmitters, this is an amazing set-up. Good luck with it as you should enjoy its operation and user friendly features.
A/C, Heating, & Refrigeration Contractor
Please be kind when rating, as I know you will be. If you have anymore questions, leave them in the comment box so I can check in when I can get to them. Thank you for using
Nov 20, 2010 | Heating & Cooling
How does a honeywell L4064b2236 work? It is set up on a Gas hot air furnace with the jumper removed, Three wire connection, black to common white to fan and red to limit. The furnace has a tranformer on...
If the jumper has been removed, then the control is working in the low voltage circuit. Black should be 120v in, White the 120 going out to the fan, and the red or limit wire is (should be) in the low voltage control circuit. Have you looked at the wiring diagram for the F and L Control? If not I will provide a link for you.
Hope this helps
Nov 16, 2010 | Honeywell L4064B2236 Fan/Limit Control...
Wiring diagram
Sep 05, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
54 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
