Question about Vehicle Parts & Accessories
I have a 2001 Chevy Monte Carlo and I recently replaced the battery. I didn't know it had to be hooked up to an alternate source of power and now the anti theft lock is on and the radio won't play. Can someone help. I do not have my owners manual anymore. Is there some kind of code or some way to override it to make the radio work. Thanks Lisa l.ferguson1968@hotmail.com
    Sergeant:
  • 449 Answers
Usually radio connections are given from Accessories position of Ignition Switch. Check the wiring. (ehteshamhusain@gmail.com)
Posted on Jul 20, 2009
1998 Chevy Monte Carlo - Doesn't start. Replaced the alternator
start the car then remove the negative battery cable if the car still runs them your alternator is working properly and you need a battery. I have also gotten bad rebuilt alternators from on several occasions for this type of car and had to put on new AC delco ones but they are a little more expensive.
Nov 24, 2013 | 1998 Chevrolet Monte Carlo
How to change an alternater on my 2001 chevy monte carlo
pull neg battery cable take off wire, unplug plug,remove belt , one bolt on top one on bottom use pry bar to loosen and remove install in reverse order make sure battery is charged before start or damage to new alternator may occur,
Aug 04, 2012 | 2001 Chevrolet Monte Carlo
99 chevy monte carlo was running fine, then one day it didnt start, no lights or power from battery. What could this be?
Possible Problems 1. Battery dead (if the horn does not blow then that's what it is) 2. Alternator is malfunctioning (the thingy that makes the sound when you turn the key in the ignition)
Aug 26, 2011 | 1987 Chevrolet Monte Carlo
I have a chevy monte carlo ss on my way in the battery light was flashing and the volt meter was going down to 0 what could this be? and now I can't start my car.
THE ALTERNATOR MOST LIKELY THE PROBLEM, IF THE BATT IS GOOD, THEN IT WILL CHARGE BACK UP WHEN THE CHARGING PROBLEM IS FIXED...HOPE THIS IS SOMEWAY HELPFUL
Mar 04, 2010 | 2001 Chevrolet Monte Carlo
How do I replace the alternator on a 97 chevy monte carlo
The 3.1 and 3.4 have the alternator mounted on top. Disconnect battery and remove drive belt, the alternator is mounted by three bolts, good luck.
Jul 18, 2009 | 1997 Chevrolet Monte Carlo
Pulsating or flickering lights
your car is in denial.... Have your battery load testest. If it has any plate issues it can mislead the alternator regarding its state of charge abd, by all means make sure your battery cables are clean and tight. good luck
Jun 08, 2009 | 1999 Chevrolet Monte Carlo
Battery light flashes red car shuts off while driving
try making sure the battery cable and alternator is grounded
Apr 15, 2009 | 2001 Chevrolet Monte Carlo
I need to replac my seatbelt in my 2001 chevy monte carlo
take off the trim panels on the bpillar and you should be able to put in but hey will need to be reset. before you put that in disconnect battery and it may reset.
Jan 23, 2009 | 2001 Chevrolet Monte Carlo
Jump starting a chevy monte carlo 1997
negative any metal part of engine wiggle the cable to have good contact that it cheers pierre
Jun 24, 2008 | 1997 Chevrolet Monte Carlo
Vehicle Parts & Accessories Logo
131 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
