Question about Dryers
Hi Tim I have replaced the ignitor, start capacitor, flame control put new kenosense in it and it still does not work!!!
  • Dryers Master
  • 5,323 Answers
WHAT IS IT DOING OR NOT DOING?
Posted on Dec 08, 2016
Gas dryer runs but no heat. Took it apart cleaned all ducts and lots of years worth of dirt out of entire machine, looks brand new. Tested all components.
You did quite a bit of work. One other thing that controls the ignitor is called the flame detector. Its the black box looking thing mounted on the side of the big pipe the flame shoots into. Should be 2 wires going to it. A quick test to see if the ignitor comes on is to tie the 2 wires together. If you see the ignitor come on thats the bad part,
Jun 29, 2015 | Dryers
Heatman, please help: Bake burner cuts out
Try cleaning the pilot nozzel with compressed air. I had the same problem with my fireplace.
Dec 09, 2012 | Ovens
Ignitor works, lights the gas, then when the ignitor goes off, so does the flame.
Hi Stanley,
the problem with the dryer flame going out is caused by defective coils on the gas valve and the gas valve coils should be replaced
Dec 03, 2011 | Speed Queen Dryers
The igniter glow bar gets bright and hot on the first burn in the drying cycle, however on subsequent urns it doesn't glow bright or long enough to ignite. What's up?
The ignitor is either going to be good or bad. If it fires off it is fine and if it is shutting down then the flame sensor is also working. That tells me your coils are weak and old.
Here is how it works and why I believe you need to get new coils: When the dryer is cool first thing in the morning the initial start up the fuse and control besidethemobilian_2632.jpg
it allow power to the gas assembly, the flame detector/sensor allows power to get to the ignitor and it begins to glow. 1800 degrees is what that baby puts out and at that point the flame sensor bi-metal bends and shuts down the ignitor. The holding coil and secondary coil will then have enough power partially because the ignitor is off and partially because the ignitor is now acting as a thermocouple. If for some reason the gas did not ignite then the ignitor would cool down and shut off the gas. themobilian_2633.jpg
When the temp inside the drum gets to 160f that control beside the fuse shuts off the gas assembly, IF it don't shut down the gas then that fuse melts and shuts down the power to the gas assembly but it doe not shut down the dryer. The fuse is good though because you are getting power to the gas assembly AND the gas assembly is shutting down at 160f. The dryer keeps a tumbling around till the temp in the drum drops to 105f at that time the dryer wants another blast of hot air, trouble is the coils have gotten hot now, the ignitor is doing its thang, the flame sensor is doing its thang, the control is doing its thang. The only thing that ain't happening now is the coils ain't allowing gas to come out. Replace the coils and party on! More here
Jul 18, 2011 | Kenmore 400 6942 Dryer
Furnace was working fine and just stopped working...it reacts to raising the thermostat but doesnt actually flame on
This is probably a ignitor.
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks.Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. Please see "limits, rollout switches & furnace control boards" further down on this page. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Please leave feedback... Thanks...
Jan 28, 2011 | Goodman GMS90703BXA Heater
Hot surface ignitor won't ignite,I replaced the igniter and it still won't.
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Oct 25, 2010 | Heating & Cooling
Dryer is not putting out heat. Gas is connected and working in other parts of the house near the dryer.
Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Nov 24, 2009 | Roper RGX4634KQ Gas Dryer
Dryer will not start when button pressed. Several times yesterday it did start but stopped few minutes later.Kenmore brand. Model 11062812101. Serial MM1310180. Thank you
is it a gas or electric model, if gas the ignitor,flame sensor,control board,if its electric,element,hi-limit,thermistor switch, control board, lack of correct input voltage,bad motor start capacitor on either model
Nov 01, 2009 | Dryers
Heating /AC Unit Nordyne M1M Blinking Yellow Light
I'm not trying to be a smart alec but, did you know that that yellow light might be part of the diagnostics. If you can read the tiny print on the back siide of the acess panel. There should be an explanation of what the light means. At least thats how mine works.
hope that helps,
RSMITH972278
Oct 15, 2009 | Heating & Cooling
Dryers Logo
Top Dryers Experts
