Question about Ovens
C2 c3 error code jenn air oven - Ovens
catriver
  • 878 Answers
SOURCE: F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Posted on Dec 04, 2007
  • 146 Answers
SOURCE: Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Posted on Jan 07, 2008
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: jenn air combo wall oven/microwave
Bend over, pull down pants. They Got you....
Posted on Apr 26, 2008
SOURCE: error message on JJW9530DDS Jenn-air wall oven
no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
Posted on Jul 22, 2010
Tip
Jenn-Air Oven 4D22 Fan Error
I was troubleshooting one of these error codes on a Jenn-Air oven and followed all the repair recommendations. Most service techs recommend replacing the fan, speed sensor and making sure everything is clean. I did all this and it made no difference. After a bit more troubleshooting I found the temperature sensor to be bad. I replaced the temperature sensor and the fan fault code disappeared and the oven worked normally.
on Dec 09, 2016 | Jenn-Air Ovens
How do you fix a JennAir wall oven display? The oven heats and the over light works but no display.
u can pull the display board & the c3 capacitor is usually burnt. Pretty common problem with jenn air. You can buy it at radio shack r any electrical supplier for bout $2 r $3 bucks. You will need some soldering skills but its not to hard.
Jan 10, 2015 | Jenn-Air Ovens
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
Error code -fc- beeping will not stop?
From JENN AIR FAULT CODES...
FC - Communication error between boards - Wiring harness or power relay board (PRB)
Hope helps.
Mar 24, 2011 | Jenn-Air Electric Double Oven
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
