Question about Sanyo SR-4310 Compact Refrigerator
Re: Sanyo SR4310W mini fridge freezer plate broken
Re: Sanyo SR4310W mini fridge Was defrosting & chipping out ice and punctured freezer plate (evaporator plate?) and freon released. Can I replace this part? How much? Source it where? Or, is it so costly I'm better of buying a new one?
Ok, I know I should not have done this but I did. I was impatient with the defrosting and stabbed my Sanyo SR3770s' evaporator with my Smith and Wesson switch blade knife. A very tiny hole, made a swooshing noise and now the fridge won't get cold. Can this be repaired for a minimal price? Perhaps just replacing the evaporator plate and reinstalling some freon, maybe, hopefully?
Let me know. Basically a brand new unit, hate to see it go to the dump!
Sandra
Posted on Dec 30, 2010
Why would I be getting water build up to ice below the meat tray?
The unit self defrosts and this creates water. There is a drain tube that is supposed to let the water go to the bottom of the outside underneath. If that tube is plugged or damaged the water runs down the inside and creates ice.
Apr 25, 2015 | Samsung RF266ABRS Bottom Freezer...
Will trying to chip away ice in the small freezer part i punctured something. How will this effect the fridge? Will the fridge still stay cool, and just the freezer part not work, or do i need to buy a...
If you've punctured a section that allows the refrigerant gas to escape, the following can happen:
1. If you switched the unit off immediately after, then the puncture can be sealed, and the unit 're-gassed'.
2. If the unit was left to run, there is a real possibility that the compressor could sieze, resulting in repair costs that would exceed replacement costs.
Jun 08, 2011 | Refrigerators
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
I was defrosting my fridge and punctured the tube
might be possible, depending where exactly the puncture is, but if it was repaired it would need
regassing to the correct level, you would need a professional refrigeration engineer,
Dec 12, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
How do I defrost a Samsung Refrigerator # RS2555SW?
Take the back cover inside the freezer off and you can see the iced up coils. Use a hairdryer to melt the ice. Don't chip it off, you might puncture the coil.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 08, 2009 | Samsung Refrigerators
Chiping ice out of freezer section with chisle and entered a "cavity" under freezer shelf...seemed like freon gas came out of it. Is the refriderator toast? It is a Magic Chef mini-freezer.
Sound like you punctured one of the molded channels in the freezer shelf that carries the refrigerant.  Probably can't be fixed.  Possibly could be replaced.  Consult a service technician if the fridge is new enough to keep.  If it does not have an auto-defrost or frost-free function it is probably too old to be worth repairing.
May 19, 2009 | Refrigerators
Sanyo Mini Fridge
Nope the evap line is aluminum and can't be soldered onto the suction line sorry
Sep 09, 2008 | Sanyo SR-4910M Compact Refrigerator
Fridge freezer
did your friend use a knife to prize off lumps of ice? i bet he/she did and has punctured the evaporator. if so, not repairable
Jul 04, 2008 | Zanussi Freezers
Sanyo SR-4310 Compact Refrigerator Logo
1,708 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
