Question about Hilti Drills
The fan for the te22 drill
Serial340119 volt 110 make hilti te22 or where can i get spare parts
    Habit-Forming:
    New Friend:
  • 121 Answers
Hi
I very much doubt if you can get one as the fan ( plastic )
is bonded to the rotor spindle
Posted on Jan 29, 2018
rowdy45176
  • 2176 Answers
SOURCE: Problem with Hilti JackHammer TE76
Yes there is but it is somewhat confusing to navigate. It is Hilti.com. If you can give me some idea what parts you are looking for I have that breakdown at work and will help you. It is the TE76. Let me know and I will do what I can or you can call their toll free number in the US at 1-800-879-8000 and ask them for help also
Posted on Jan 27, 2009
  • 123 Answers
SOURCE: how long does it take to fully charge the battery
The 10A has not been sold for over 15 years. When the batteries are in good shape it took around a hour to charge. If yours is taking longer than that it could be the batteries are bad. I would also look at the contacts on the battery and the drill. These had a tendency to get bent,
Posted on Oct 09, 2009
  • 61 Answers
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
Posted on Oct 11, 2009
  • 123 Answers
SOURCE: Parts for a Hilti TE72
Ebay would be your best bet. Hilti has not produced that drill since around 1992. They no longer have parts for it. That is a double throw switch. Usually the side that is burned out will be discolored or loose at the contact. If it is the left side you can take the bottem left wire and hook it to the top left wire at the contact. Or do the same if it is the right one.
Posted on Apr 03, 2010
  • 123 Answers
SOURCE: drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
Can I convert a Hilti te5 from Chinese plug to American?
Check your voltage first. The USA uses 110 volts? Chinese electricals run on 220 volts. Somewhere on the Hilti it will tell you what voltage is ok.
You can probably buy an adaptor to fit the Chinese plug into. However, it would be easier just to cut off the Chinese plug and fit one of your own.
Mar 13, 2016 | Hilti Drills
Need a cooling fan for hilti hammer drill te22
Claudette,
From my experience with Hilti tools, you have to send the tool back to them for repair. I have not had much luck in getting any parts from them. Sorry!
May 07, 2015 | Hilti Drills
Parts manual hilti te22
Try this page;
https://www.elektrikmotorbobinaj.com/urun/te22-acilim-semasi-teknik-resim/665
Dec 19, 2012 | Drills
How to Replace Hilti TE22 chuck
You put the two flat sides on the end of the cap nut and lock them in a vice. You then put a wrench on the back side of the chuck which also has two flat sides. with the cap nut locked in a vise take the wrench and turn the retaining sleeve which has the two flat sides counterclockwise to break the cap nut loose. When it turns freely take the chuck out of the vise and turn the cap nut off. You then push the ribbed locking sleeve down to access an o-ring. You pull that off and it releases the locking sleeve and two roller bearings. You then pull off the retaining slv with the two flat sides and release the other two roller bearings. the chuck will then just pull off the shaft
Hope this helps
Sep 30, 2012 | Hilti TE 7-C 120V Rotary Hammer Drill
I need a switch and brushings for my HELTI TE22 Hammer Drill
You need to contact a Hilti dealer either in person or online.
May 14, 2012 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Hilti te22 trigger problem
the switch for the TE22 has been discontinued for years. Your best bet is to find a used one on ebay. Since it is a double throw switch somtimes you can get away with jumping one side "the bad side" and getting it to work for a while. The cord goes on the top connectors and the motor on the bottom. If you determine that one of them is bad then take the cord wire and move it directly to the motor connection below and secure it with the motor screw. A quick drawing below to show what I mean.
Hope this helps
Glenn
Nov 10, 2011 | Hilti Drills
Need locations in europe and asia for spares outlet and price for armature assy for hilti TE 2s drill - ( due to short in windings and comutator) purchased on 1981 from saudi arabia -
Go to Hilti's website and choose your country. You can find locations and parts. The TE2s was not introduced until the early 2000's. In 1981 a drill that size would have been a TE12s. If that is your model parts are no longer available through Hilti.
Dec 25, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
I own a Hilti SF 150-A 15.6 volt cordless drill ( non hammer type ). I need a trigger assembly for it. Where can I order one?
As i know Hilti has a free of charge repair or replacement of defective parts; Hilti tools are covered by a lifetime manufacturer's warranty against material or manufacturing.Call them direct at 1-800-879-8000, the only place I know to get parts from is Hilti.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 18, 2010 | Hilti Cordless Drill Driver SF 151A 20Ah...
Drills Logo
117 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
