Question about Dryers
Can 2 bulb heater fan, model 9427P be installed in ceiling of a shower?
Brand is Nutone
    Top Expert:
  • Dryers Master
  • 77,939 Answers
Posted on Dec 07, 2016
Nutone Model 671 Died and need Replacement
You should be able to use any replacement by Nutone. The kit should have finishing rings to install and cover anything from the old one.
Mar 12, 2014 | Broan-NuTone Dryers
Ceiling fan not working. How do I remove the fan to see if the vent is clogged?
Usually the cover pulls down, and is suspended on wires.
Push together the wires to release cover.
Use vacuum to clean.
Dissemble using screwdriver if possible. Some newer fans are one-piece and cannot be taken apart.
See if fan turns on.
Open wire cover and inspect wires.
Use non-contact tester to see if unit has power when switch is turned on.
See if switch is good.
If fan does not turn on, then wires are loose, switch is bad, fan motor is bad.
Some fan motors are sold separately, and some are not, and whole unit has to be removed from between the joists, and new fan installed.
Dec 05, 2011 | Broan-NuTone Nutone 70 CFM Deluxe Ceiling...
I need a heating elament for my Braun model qtx100HL-A ceiling fan heater. I took it out and it is a 6260 eichen 120 v / 1425 watt
My Nutone Model 765HL uses the same heater; I tried the Broan-Nutone website but they were out of stock. Finally found it at Central Vacuum Stores for $35. Here's the direct link:
Hope this helps!
Sep 06, 2010 | Broan-NuTone Heating & Cooling
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
I have a thermador bathroom ceiling heater fan. Where can I get a replacement? bathroom ceiling heater Broan Product Detail
If you have the old Thermador ceiling type of heater that must be mounted on the ceiling surface there aren't many choices. Only the Broan-Nutone 154 & 157 models. The 154 @ $37 didn't seem to last too long but it's 1/3 the price of the radiant 157 model at about $100+ dollars. The radiant model may last longer
Sep 02, 2009 | Heating & Cooling
Older Nutone bath- fan/light/heater Model #9111. Light works, fan and heater do not. Must I replace the entire unit.
Most of the time is is cheeper and less time consuming to replace the unit than to find what happen to it and then order parts to repair it.
Aug 28, 2009 | Broan-NuTone (8663RP) Ceiling Fan
Need to change light on old nutone heater
If there are no visible screws and no knob in the middle of the grate to unscrew you have a model which simply pulls down. If it has been up there for a while it may have been painted over so you will have to use a razor blade knife to cut through the paint around the perimeter. Once that is done, use a putty knife to carefully pry the grate away from the ceiling about one inch at a time, working your way around from side to side.
May 17, 2009 | Broan-NuTone N671 Nautilus Ceiling Fan
Bathroom fan
You'll be able to access the motor to service it and the wiring junction box from inside the bathroom. Please rate this answer if it was at all helpful.
Jan 31, 2009 | Broan-NuTone Designer 721 Ceiling Fan
Dryers Logo
48 people viewed this question
Top Dryers Experts
