Question about Home
Mt vernon pellet stove unit comes on lights then goes out after a minute
SOURCE: St Croix pellet stove: pellets drop
http://www.jaygaulard.com/blog/2009/01/18/how-to-clean-out-a-st-croix-prescott-exl-pellet-stove/
Posted on Feb 24, 2009
protek480
  • 1714 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
  • 744 Answers
SOURCE: Harman P68 pellet stove glass fuse blows after 1 minute.
You can do some troubleshooting by looking at the glass fuse after it has failed. If the element looks melted and there is no other discoloration, then the fuse probably blew as a result of an overload somewhere. If the fuse is burned black, then it's probably a short in the system.
You can meter the motors to see if they are shorted anywhere or open.
It sounds like you may be correct about the circuit board.
Posted on Jan 02, 2010
SOURCE: 5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Posted on Feb 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Pellet stove flashing H2 and won't reset
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Harman pellet stove blower not coming on. All lights are on and not blinking.
well im not sure why a pellet stove question is here in the pool section , but I do own a pellet stove (and a few pools too) SO I can offer one thing to look for , there is a small switch on the side of your burn chamber (soup can looking thing) this switch is what controls your fan to come on . it works by sensing heat from burn chamber and then turning power on to fan , its possible this isn't passing any power on yours ?
Oct 04, 2016 | Home
Tip
Alternative Heating Pellet Stoves and Pellet Inserts
Pellet stoves usually use wood pellets as their primary heat source. A pellet stove is defined as a stove that burns either compressed wood or biomass pellets to make heat to warm a home or other space.
Pellet stoves come as either free-standing units or fireplace pellet inserts which can be vented into an existing chimney. As an insert, you are able to replace your wood burning stove with this efficient and cost effect stove. Inserts also give the homeowner more of the look of a fireplace than that of a pellet stove. Pellet inserts can also be a great alternative for people who have busy lifestyles and are looking to get the beauty of a fire but prefer a cleaner burning renewable heat source.
Pellet stoves are freestanding structures that can give you the feeling that an old pot bellied stove did, tucked into a corner of a living room, den, or kitchen. Either the pellet inserts or freestanding stoves are a great alternative heating solution for keeping a house warm during the winter.
Many stove manufacturers recommend the using a corn and pellet mixture, but some are UL listed for many fuels other than pellets. These can include wheat, corn, sunflower seeds, and cherry pits.
Pellet stoves are a bit more efficient, burn cleaner, and are easier to use than conventional wood burning stoves. Pellet stoves often look very similar to wood stoves or fireplace inserts, however the similarities end there.
If you are considering burning alternative fuels then you will want to look into a pellet stove as a great way to heat your home. Pellet stoves and pellet insets have many great advantages over regular wood stoves that make them a practical heat for busy lifestyles.
on Dec 07, 2009 | Heating & Cooling
What is causing the ready light to flash red twice when I try to light my pellet stove
[PDF]INSTALLATION AND OPERATION MANUAL - Wood Pellet...
woodpelletheat.com/WinslowManual.pdf
by P Stoves - ‎Related articles
Please read this entire manual before installation and use of this pellet fuel-burning room .... FLY ASH BUILD-UP: For all wood pellet fuel-burning heaters, the combustion ......Ready Light - lights up when stove is ready to operate. Igniting Light ..
Sep 27, 2015 | Pool & Spa
What are the pros and cons of operating the Quadrafire Mt Vernon AE pellet stove in manual mode?
They probably cannot suggest running it on 'manual' due to liability reasons....leaving home for an extended time and forgetting its on manual...comes to mind.
What may be suggested is to make sure ANY and ALL safety controls still function to shut off fuel (pellet) flow in the manual mode as an extended overtemp condition is the first thing that comes to mind when you think of damage to a heating system or to the structure within which it is installed.
I think its a judgement call on your part once you determine you pretty well KNOW the full and complete operation of the device. The key to that statement is KNOWING WITHOUT A DOUBT the FULL operation of the system.
I also would NEVER recommend to a customer to operate it in the manual position.
Mar 25, 2015 | Heating & Cooling
Why is my reset switch popping after 10 minutes when I try to to start the pellets.
I would suggest contacting Napoleon directly at 1(800) 461-5581 and ask for a registered Napoleon service dealer in your area. You can also go to this website http://www.napoleonfireplaces.com/find-a-store/ and ask them if they have a service technician if you are in the United States. Pellet stoves are extremely temperamental and can be a real bear to try and diagnose. Honestly, leave the diagnosing and troubleshooting to guys that have meters and gauges to properly diagnose the issue. I hope this helps.
Aug 02, 2014 | Napoleon Fireplaces Napoleon NPS40 Auburn...
Pellet stove problems
Check to see if this unit has a combustion air intake
that can be mounted to it. I`ve come across where the person was using only conditioned space air.
Jan 05, 2010 | Heating & Cooling
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
I have a 1985 Whitfield pellet stove that has problems
Check the basics first fuel (supply and quality of) Air flow and ventilation. If nothing obvious google {whitfield pellet problem]. My guess is that something is plugged up.
Mar 03, 2009 | Napoleon Auburn Pellet Stove Heater
Home Logo
24 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
