Question about Electric Kid Trax C6 Corvette Ride On
The car goes 5 feet and stops. You wait a couple
The car goes 5 feet and stops. You wait a couple of minutes...goes another 5 ft. and stops. Got another battery and it still does the same thing.
    New Friend:
I would like if possible to have the scheme for electric power faser repair. why here in my town does not have to may copy or mesmo.thanks
Posted on Jun 03, 2013
  • 850 Answers
It will be the capacitors !
should be one on the battery & one on the shift
Posted on Jul 20, 2009
On a evo Harley Davidson how do I get my pushrods lowered so I can install my rocker boxes
the push rods are at a required length to activate the rocker gear
by shortening the push rods the valves will not open and the engine will not go
if the original rocker covers will not fit after work has been done then I would go back to square one and find out what has been assembled incorrectly
Apr 19, 2015 | Harley Davidson Motorcycles
2006 VW GOLF TURBO DIESEL 1.9 STARTS UP GOES 5 TO 9 MILES STALLS WAIT 5 MINUTES GO AGAIN AND STALLS
Hi. It would be useful to get a code read and some live data from a decent diagnostic tool. There are quite a few possible causes including, pressure in tank - if the fuel tank can't vent pressure then a vacuum will eventually form stopping fuel getting to the engine, this will cause it to loose power and stall. Then after a few mins the pressure will drop and the process start again, easy test is when the car stalls remove filler cap - if that's the fault there will be an audible hiss and the car will start up again.
part blocked exhaust will have same problems but will more generally cause a lack of power and acceleration.
are there other symptoms? i.e only when conering or only when pulling off or stopping, engine light on/off. Jon
Dec 18, 2014 | Cars & Trucks
How do I do feet and inches calculations on the Casio FX-115ES Plus? For example, how can I do calculations like 10'-3" + 5'-4" + 11'-11" without having to convert the inches to feet?
You can combine all the feet together 10+5+11=26 feet
Combine all the inches together -3-4-11=-18 inches=-2 ft + 6 inches
26 ft -2ft +6 inches =24 ft +6 in=24.5 ft
You can also multiply each inch -value by 1/12
10-3/12+5-4/12+11-11/12=10+5+11 -(3+4+11)/12=26-18/12, continue
Jul 22, 2014 | Casio fx-115ES Plus Scientific Calculator
How do you calculate cubic feet?
You calculate a volume. If all the lengths, radii, heights are in feet the resulting volume is in cubic feet.
Example: Right rectangular prism with L=5 ft, W= 3 ft, height =1.5 ft
Volume =(5 ft)*(3 ft)*(1.5 ft)= (5*3*1.5) (ft*ft*ft)=22.5 ft^3
Nov 19, 2013 | Office Equipment & Supplies
I have aquashift st 2000 2300 lph pond pump my pond is only 30inx30inx20in deep i also have a waterfall height from bottom of pond to filter appx 5 ft lenth of pipe appx 10ft my problem is not...
If you look at the pump cabilities the max life is either 2.3 or 2.4 meters. I.e 7.88 Feet max lift. I looked up even the 5000 Liter per hour pump and it only has a lift of 2 meters. 10 feet is 3.048 meters. It seems your height requirement lift of 10 fee is greater than the lift capability of the pump. You can... install a second pump with a hidden reservoir at the 5 ft lift mark behind the water fall to get the desired flow. Or change to a submersible 1/2 hp well pump as most will give you 10 to 12 GPM flow rate and will elimate the 10 ft lift problem. A shallow well pump could be installed above the water (encased / hidden and provide you with 23 feet of lift.
The problem you have is the 10 ft lift distance is more than your current pump can provide.
Thanks for choosing FixYa.
Kelly
Sep 23, 2010 | Oasis Garden
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
TV picture goes out
The tv is shutting down because of a power problem. It could be the power transformer or a color gun overheating. Expect at least a couple of hundred dollars to fix it. Some shops will do house calls for around $65 and can diagnose the problem and give you an estimate. Usually they can just remove the board, take it to the shop and repair it, then reinstall it.
Nov 03, 2007 | Televison & Video
Electric Kid Trax C6 Corvette  Ride On Logo
244 people viewed this question
Top Electric Toys Experts
ray gallant
Robert A. Watson
Robert A. Watson
Tom Chichester
Are you an Electric Toy Expert? Answer questions, earn points and help others
