Question about Microwave Ovens
My microwave does hit - Microwave Ovens
How do I use the grill function on my new microwave?
I've had an Emerson microwave/grill for about 5 years now and love it!! To use the grill function you just hit "grill/combo" then hit the buttons up above the grill/combo button for however many minutes or seconds you want, then hit "Start" button. make sure your using a metal dish.
Feb 20, 2016 | Emerson Microwave Ovens
Sounds like fan blade hitting somethinWhat is wrong?
I appreciate your inquiry, Gloria armstrong!
You stated that your fan blade inside of your Frigidaire microwave is hitting something. It is difficult to provide you an accurate diagnosis with properly disassembling your microwave. This is not a simple DIY job. I would highly recommend seeking assistance from a professional technician. They would have the knowledge on how to properly disassemble your microwave without causing any future harm to your microwave. I hope this is helpful. -Matt
Feb 21, 2015 | Frigidaire Microwave Ovens
How do I turn off the sound on my new Kenmore Elite microwave?
I Believe this model has an options button with codes by numbers which are 1 thru 6 I believe. Either 1 or 2 are sound. So hit the options button and hit the number 1 it should say (sound), Then you will hit 1 again a.k.a. mute, and no more beep beep beep. If 1 is not sound then you may have accidently created a small but deadly emp, so hit stop and you must hit options and then hit 2.
Dec 11, 2014 | Kenmore EM262A5E Elite Stainless Steel...
House was hit by lighting and now my microwave wont work
It is likely your microwave was hit by a power surge associated with the lightning strike.
Jan 14, 2013 | Microwave Ovens
Buttons make numbers appear on screen
The keypad control board must be replaced in order to address the issue, but keep in mind the part alone is expensive.
Apr 18, 2012 | Microwave Ovens
Timer counts down. Microwave keeps going
It is a bad door switch, or the keypad control board is the issue.
Apr 11, 2012 | KitchenAid KCMS145J Microwave Oven
unplug and take apart and more than likely something is hitting the blade or it has slid down the shaft and is hitting the motor or the cover if u pull the blade off and plug in and it dont make the noise then the blade is hitting something if the motor is still making a noise then the motor needs replacing
Jan 11, 2010 | Maytag Appliances Over-the-Range Microwave...
I hit the lock button and it quit wrking
Hold down the "START" button for 5 seconds.
Jul 13, 2009 | Amana Radarange Microwave Oven
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Neff oven timer
Normally you enter the time digits, then hit power level then zero or hit the timer button (if so equipped) then enter the time digits and hit start.
Nov 12, 2007 | Neff H7871N2GB Convection / Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
