Question about Garden
How to disengage blades on 16 hp roper hydrostatic yard tractor
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
  • 376 Answers
SOURCE: I need to replace the blade belt on my yard works
I found the owners manual and a parts breakdown for this mower. Is this what you need? I could send you the pdf files. Just need to know where to send it.
Posted on Jun 08, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 148 Answers
SOURCE: Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Posted on Jul 27, 2009
wilsodfarm
  • 986 Answers
SOURCE: Hi I have a 16hp roper lawn tractor it is about a
hydrolic oil I use 46
Posted on Jul 29, 2009
My craftsman yard tractor all of a sudden will not move, 42 " cut , 15.5.hp kohler motor Hydrostatic drive ,!
bypass rod pulled out to allow pushing the tractor, the noise is the hydrostat bypassing fluid (normal) if my crystal works
Apr 01, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
I struck an object while mowing my yard and the tractor wont start or even crank what could the problem be?
start by disengaging the blade and putting the deck to it's highest position, prior to attempting to start the mower inspect under the mower deck making sure there is no Debee wedged interfering with the blade rotation, check your spindle's for play and inspect your mower and drive belts. once complete than give it a try. if by chance it does start but turns over you more than likely sheered the flywheel key.
Oct 10, 2013 | Poulan Pro 46Inch 22 HP Yard Tractor with...
Disengage mulch drive
Have you looked beneath the deck with someone engaging or disengaging the blade lever? Get underneath and observe how the belt travels from the engine pulley back, and follow it in the loop it travels to see how it works with the lever engaged and disengaged.
Jun 08, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
May 10, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
My riding mower workes fine fore about 45 mintes then it slowes down wants to move real slow and wont pull my yard sweper anymore. The blades engage just fine, the motor starts/runs fine It just moves slow...
Im assuming the tractor is a hydrostatic, in this case when the transmission starts to go...thats it, call the company and find a replacment or get another tractor. unfortunately rebuilding them isnt all that worth it
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have my dozer blade on the tractor but it won't lift up or down and i can't figure it out
how are the Hyd line attached?
must get right hoses in inlet and outlet.
Is tractor hydrostatic or Geared?
Nov 28, 2008 | Craftsman 16" High Garden Tractor Snow and...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
