I tried the reset, but it won't go past 62% Kathy R
2008 Jeep Liberty
Possible solution - This happened to me and my battery was dead in my key fob and also I needed an ignition switch because a piece on it was broken which therefore wouldn't turn to start the engine.
Apr 26, 2013 | 2008 Jeep Liberty
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I cant past level 62 on jewels deluxe....please email the solution
did u pass level 62 yet ? if so are u on level 68 if so help plz i dnt remember 62 but its a video on youtube for level 62
Aug 21, 2011 | RunnerGames.Studios Jewels Deluxe FreeFull
I have a designer 1. recently when i go to embroider, it starts fine then just goes hay wire and put teh embroider all over the place- not like the pattern. Sound to me like the emb. unit? thanks kathy
Hi Kathy, I'm sorry your Designer 1 is not feeling well.8*( It sounds like to me you need to get your embroidery unit re-calibrated by your local technician. When was the last time you had your machine serviced? Are the designs you are trying to embroider stock designs or your own designs? Have you tried resetting your machine by turning it off and back on again and let the machine calibrate again? (Take the hoop off before you do this and put it back on after you have selected your design) and try it again. Also how old is your machine? They had a recall on Des 1 purchased between 1999-2004 for a power supply problem. The serial # and recall info is on the Viking website at- www.husqvarnaviking.com. Also do you have enough clearance around your machine where the hoop is not hitting anything while it's embroidering that will throw it of big time! Hope something here helps you! If I can help you further you can also email me at- kats2sew@hotmail.com Happy Sewing!! Kathy ( from 1 Kathy to another)
Nov 02, 2010 | Husqvarna Designer I
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Jul 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
My delphi xm is frozen
My radio was stuck on "scanning media" and the regular reset (volume up and Mode) did not work.
Nothing that I did, fixed it...
I called Delphi and they said...
(1) Put radio in it's cradle, press Volume UP/Mode buttons for 3 seconds until it resets.
(2)Then when the "scanning media" message appears press up arrow, down arrow, up arrow.
My delphi screen unlocked. I LOST everything that I had recorded, but that was fine with me.
I had to update the firmware and everything is working fine.
Losing all my recorded songs was much better than having to send in my radio!
Hopefully this will work for you!
Delphi was extremely helpful and very nice so don't be afraid to call them if this doesn't work!
Jul 10, 2008 | Delphi SKYFi3 XM Radio Receiver
Wash options
If its working ,DONT FIX IT!  try not to focus on the minutes its taking,and youll be  better off.
May 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Televison & Video Logo
Top Televison & Video Experts
