Question about Dryers
How do you remove the coversendon a Lasko model 5620 to review the thermal fuse and what size fuse is needed for replacement
SOURCE: thermal cut off fuse replacement
I worked for sunbeam and they were 10amps there. dont go to high because u start a fire ..also while you replace it look for darker or blacking field wires..all wires should look good. but hard to start a fire when u got your finger close to off the button at most it will do is slow down and stop ...smoke...time for new blender then. CrazyLarry
Posted on Jun 30, 2007
SOURCE: lasko heater model 5620
Underneath the heater element are two thermostats that are run in series with each other. Inside the wire that connects them is a thermal fuse that opened up. Replacing the fuse corrected the problem.
Posted on Nov 10, 2008
SOURCE: thermal fuse
kenmore model721-8040 nothing works no light or controll panel
Posted on Feb 01, 2009
farfield
  • 462 Answers
SOURCE: Cannot get the heating element to turn off properly on Lasko 5620
From whatI have seen on base board heaters if I recall correctly, the thermostat may be sepperate. Usually thermostats on these have a round knob. 1 line goes to this and the other side of the thermostat goes to 1 end of th element and the othe line attaches to the other side of the element. Its possible you have the element wired in directky if it came without a thermostat and without instructions it may till be connected directly. You should have an L1 and L2 connection and hope there is a wire diagram on the cover.
THE reason these basebord heaters used to come without a thermostat is because they are (OR WERE)set up to add on additional heaters comming right on down the wall. At the last one you could tie in and get a correct rated thermostat installed in the center of the series.
Return to LOWES and ask them to remove the instructions and copy them for you from another like model. Or have them contact the manufacturer and request they fax a copy of instructions with a diagram. Also ask if the heater comes with a thermostat. It may stoill be sepperate in another kit.
Posted on Mar 04, 2009
SOURCE: Replacing Thermal Fuse in Sony Grand Wega KDF-E55A20
blinking red power light 6 times. Tv picture goes on and off. Then the red lamp light came on? Now nothing.
Posted on Jan 19, 2010
18 inch adjustable pedestal fan model s18902
Alice, Check the attached Lasko Fan video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
18 Lasko Cyclone Oscillating Stand Fan model S18902
How to Assemble Lasko Pedestal Stand Fan in Minutes with No Tools
18 Lasko Cyclone Oscillating Stand Fan model S18902 again
Lasko 18 fan review
Jun 05, 2016 | Lasko Dryers
Lasko 18" cyclone 1843 quit working is there a fuse
  • Lasko Cyclone fans have a thermal fuse (typically 130 degrees C) placed on the armature of the motor, connected between the input voltage line and the start capacitor. It is not user replaceable, since it is soldered, taped and attached to the armature with cable ties. When the motor overheats, the thermal fuse blows, primarily protecting against a fire hazard. Like most low cost Chinese manufactured fans, the motor uses low quality sintered bronze bushings instead of ball bearings to save a few pennies in cost. The bushing (each motor has 2) is surrounded by padding which is infused with lubricant, and the lubricant seeps through the bushing to lubricate the rotor shaft of the motor when it is operating. Unfortunately over time, the lubricant dries out or the bushings clog, causing the rotor friction to increase, resulting in the motor current increasing as it tries to maintain motor speed. This heats up the armature coils, causing the thermal fuse to eventually blow. While the thermal fuse can be replaced with some effort and the padding re-lubricated, eventually the same thing will happen because of the low quality bushings.
Jul 05, 2014 | Lasko 3520 20-Inch Cyclone Fan
Lasko outdoor tower fan #4305 no electricity getting to it. Is there a fuze?
There is a thermal fuse on all fan motors. When the motor heats up too much, this thermal fuse blows up. You may replace the thermal fuse or bypass it entirely but you will need to open up the motor, trace the line where the fuse is connected, usually the thermal fuse is connected to the starting capacitor and the main supply line. If you're up to it, please let me know so I can guide you step by step. It's kinda hard to do. Most repair technicians will tell you to just replace the motor.
Jun 27, 2014 | Dryers
Where is thermal fuse on lasko fan
Lasko Cyclone fans have a thermal fuse (typically 130 degrees C) placed on the armature of the motor, connected between the input voltage line and the start capacitor. It is not user replaceable, since it is soldered, taped and attached to the armature with cable ties. When the motor overheats, the thermal fuse blows, primarily protecting against a fire hazard. Like most low cost Chinese manufactured fans, the motor uses low quality sintered bronze bushings instead of ball bearings. The bushing (each motor has 2) is surrounded by padding which is infused with lubricant, and the lubricant seeps through the bushing to lubricate the rotor shaft of the motor. Unfortunately over time the lubricant dries out or the bushing clogs, and the rotor friction increases, causing the motor current to increase. This heats up the armature coils, causing the thermal fuse to eventually blow. While the thermal fuse can be replaced with some effort and the padding re-lubricated, eventually the same thing will happen because of the low quality bushings.
Mar 03, 2014 | Lasko 3520 20-Inch Cyclone Fan
Cant get the heat to go past 71
Check your thermostat. Maybe it's cutting off ahead of the set temperature. May need recalibration or replacement.
Nov 12, 2012 | Lasko 5620 Electric Baseboard Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
Need manuall for model 5620 electric baseboard heater
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Jan 04, 2010 | Lasko Under Desk Space-Saving Area Heater...
Box Fan Termal fuse/capacitor> bypass
the thermal fuse is for safety reasons
The Lasko fan I have that stopped working needed the thermal fuse replaced
go to radio shack they have them
Aug 06, 2009 | Lasko 3720 Floor / Box Fan
Yellow caution light
I also have the model 5620. with the yellow caution light on. After taking the unit completely apart I found 2 thermal fuses on the bottom of the unit(appox. size of a nickel). They are located under 'U" shaped brackets which are below the medal heating element. The thermal fuses do not reset. you could test them with a drip or two of souder or wire on the top - if you ran the heater this way it would be a safety problem as the fuse would be overridden. I am throwning mine away.
Mar 16, 2008 | Heating & Cooling
Lasko heater model 5620
Feb 12, 2008 | Heating & Cooling
Dryers Logo
26 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
