After refile ink resum bottomalawayes show - Office Equipment & Supplies
Hello, I have replaced the ink cartige with an kit refill ink, not with some original cartige. At first it worked, now it shows me that the Black cartige is empy even if if have made the refill. I do not...
all you have to do is to press and hold Resume button for more than 5 seconds, this procedure will by pass the ink level counter and your printer will work with no problem.
Jun 06, 2011 | Canon Office Equipment & Supplies
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Nov 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My Canon Pixma MP220 is has an error code U051 Chk Ink Blk Col, but i have just refilled my ink cartridges
Using refilled ink cartridges will get this error. You have to reset the waste ink levels by doing the followin
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click “Resume” button and then release Both Buttons.
  5. Click “Resume” for four times then click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Aug 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Pixma 240 refilled cartridge but printer flashes error and the black ink light comes on.
Try to press and hold the resume button for 5 + seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 05, 2009 | Canon PIXMA MP240 All-In-One InkJet...
I have refilled my main black ink cartridge on my canon pixma ip 3600, my printer won't acknowledge the refilled cartridge, is there anything I can do about this?
This is because the ink cartridges has a memory chip.It monitor ink levels.Press and hold the resume button for 5 seconds.This operation releases the function for detecting the remaining ink level of the above ink.The printer shows empty cartridges but it will printing.
Nov 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My printer is saying the yellow ink is run out but i got it refilled today and still saying it.
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On most printers this happen with push resume button and hold it for 5 seconds.
Oct 06, 2009 | Canon MP610 Photo All-In-One Printer
Catridge problem
when printing try to press resume button for about 5 seconds
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
We had just refilled the ink cartridge for canon ip1980
please reset manual first by pushing power button before plug in AC cord, then push resume button twice and release both, if still happen please reinstall driver
Mar 03, 2009 | Canon PIXMA iP1600 Printer
I have refilled the ink cartridges on my Canon Pixma MP220 printer but how do i reset the printer to show the ink level is replaced as it is still showing low ink-thanks
try this
  1. Turn off the printer
  2. Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  3. Hold the Power Button, release the Resume Button.
  4. Not releasing the Power Button, double click “Resume” and release Both Buttons.
  5. Click “Resume” for Four times
  6. Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again. dont forget to rate thank you
Nov 30, 2008 | Office Equipment & Supplies
Reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
  1. Power off printer
  2. Hold RESUME button then press and hold POWER, the beeper will sound once.
  3. Hold POWER and release RESUME
  4. Press RESUME twice
  5. Release POWER button
  6. When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
  7. Press POWER to set data
Jan 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
24 people viewed this question
k24674
jasbo
jasbo
