Question about Mitsubishi Televison & Video
How do i reset lamp counter on mitsubishi 52725
Slinteriors
  • 8617 Answers
SOURCE: How to reset hours (4000) after replacing lamp
when you replace the lamp as soon as you power up the set it should automatically bring up the menu asking if you have replaced the lamp and would you like to resett the lamp hrs. Your problem is not with the lamp. its most likely the power pwb capacitors. You can get the repair kit at the following link with instructions.
http://servicemanuals.vstore.ca/
Posted on Sep 25, 2008
nick_helpap
  • 334 Answers
SOURCE: reset lamp counter on Sanyo Projector PLC XU100
in main menu lamp reset in settings
Posted on Oct 07, 2008
SOURCE: How to reset the DLP TV Lamp Counter
Press and HOLD the ENTER (or OK) button on the TV
Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference.
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter For certain models, you might have to tweak these steps slightly…offer your inputs!
Posted on May 17, 2009
saidneurot
  • 128 Answers
SOURCE: Need to reset the Lamp counter.in my Samsung HLR5667W
here you go here is this web site where you can see how to reset your lamp
Posted on Jan 15, 2010
SOURCE: reset lamp life counter pt-50dl54j
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
Posted on Jan 02, 2011
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Had a power surge and now the lamp notification is on steadily
This is a common problem and usually shows up when power is interrupted. The capacitors in the micro, digital, and power supply have to be replaced. In my shop, we prefer to send the chassis to Mitsubishi and they repair it. Do you have a local authorized Mitsubishi service center near you?
May 28, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 projection TV .I replaced the lamp ,but the red lamp light still flashes and the TV does not turn on
the computer in your tv is bad, but someone can fix your problem , just need replace capacitors 1000 to 16 v
Jan 19, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The green light keeps blinking on my WD 52725
Install The C26 DM and V26 Power repair kits available from www.tvrepairworld.com the kits contain the replacement capacitors and the CD with detailed repair instructions.
Dec 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Mar 05, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Sep 25, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725
SEDI-POSSIBLY YOUR SET HAS A LOW 5 VOLT POWER SUPPLY.TEST VIA VOLTMETER ON PLUG J-9 WHICH IS ON LITE ENGINE .YOU WILL NEED TO REMOVE BACK OF SET TO MAKE THE TEST.IF 5 VOLT IS LOW BEST TO CALL A MITSUBUSHI TECH.JOE TV
Nov 29, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
