Question about John Deere Garden
Johndeer6400 automatic transmission troubleshooting cannot move
Grind gears when engaged oillevel fine
ILikeBMW
  • 117 Answers
SOURCE: automatic transmission doesn't shift into gear right away, there is a long lag before it engages
Hello There
Sounds like your transmission oil needs to be changed, when was it last changed?
Hope this helps, please don't forget to rate me.
Posted on May 20, 2009
SOURCE: automatic transmission wont catch into any gear
You sould have been moore frequent on your transmission fluid changes, and you shouldn't have taken it to Jiffy Lube either. Your best bet is to drain and fill the trans fluid run it shift gears. Drain and fill again. Do this 3 times. Yeah the transmission fluid is expensive. on the last drain and fill you want to get a bottle of LUBE GUARD from NAPA or who ever sells it. put the whole 10oz bottle in. Shift Rev, 1, 2, 3, D. Neutral Rev D. If that don't work then you have bad seals.
Posted on May 27, 2009
  • 87 Answers
SOURCE: Subaru won't start
You've got to assume that the trans oil change is unrelated. With the key in the run position see if the wipers work, if not the battery is dead. Otherwise, try rocking the car back and forth while in park and then hope for a miracle. If all fails, get out the volt meter and start measuring voltages at the starter and the power pack (coil).
Posted on Jul 09, 2009
  • 33 Answers
SOURCE: my automatic gear shift will not engage. It
your shifter cable popped off
Posted on Nov 19, 2009
  • 5 Answers
SOURCE: 2001 buick century transmission problem
it could the trannie solenoid or filter.
Posted on Dec 07, 2009
My smart fortwo will not engage automatic or reverse
If the ABS has a problem , the transmission will not work properly
Mar 30, 2015 | Smart Cars & Trucks
97 Corolla Automatic Transmission problems
Torque Convertor or clutches. Strip down and find out what it is.
Jun 16, 2017 | 1997 Toyota Corolla
My 92 accord shift level moves but will not engage any gear
First check the trans fluid (if its not a sealed transmission). They wont shift in gear if they are to low. If that is fine, The shift solenoid has most likley gone bad.
Oct 13, 2012 | 1993 Honda Accord
99 s10 blazer shifts fine into 2 gear but wont shift into 3rd
For gear shift issues and gear stuck issues,the help links are provided below. Click the link below to go through troubleshooting procedure:---- ---- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ---- transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ----- Transmission not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ----- Vehicle only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
---- Engine will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html ---- Car stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html ----- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
--- Car wont downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
---- Transmission will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
----- Auto wont shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html ---- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
----- Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
---- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
------- Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
----- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
------ Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------ Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
------- Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
Mar 08, 2012 | Blazer S10 1999 99
1993 mercedes benz 400E wont shift into 3rd gear
This will help.
Thanks.
Feb 12, 2012 | RTO Automatic Transmission And Engine Oil...
2004 Trailblazer shifter stuck on Nueutral can't move to park or Drive
This will help.
Thanks.
Feb 04, 2012 | 2004 Chevrolet TrailBlazer
96 e320 Mercedes benz stuck in park but starts fine.
This will help.
Thanks.
Feb 04, 2012 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
1988 Ford Bronco Transmission Issues
is the idle speed correct? do you shift into second before trying to engage reverse?, is the clutch ok, this is most likely not the trans at all but one of the above issues, the clutch is my guess.
Sep 14, 2009 | 1988 Ford Bronco
None of the gears will engage
it sounds like something broke inside the transmission
Jun 16, 2009 | Ford Ranger Cars & Trucks
I have a 1999 Cadillac Esclade,Automatic Transmission
internal transmission problem. Unless you know how to rebuild a transmission it is best to take the dealr or a transission repair shop like AAMCO.
Mar 15, 2009 | 1999 Cadillac Escalade
Garden Logo
37 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
