Question about LG Rumor LX260 Cellular Phone
The charging port came completely off on my LX260
How do you repair the charging port? What if I were to get a broken phone (e.g. cracked display) how could I "cannibilize" to fix my original one?
  • wblund Jul 23, 2009
    So are there any good instructions on how to disassemble the phone and/or get to the motherboard- It looks like keeping the sticker intact is key. I was able to find a phone that has a white display problem (not cracked) - it's in pretty good shape - so swapping the mother boards would give me the good port and I'd be back on my way. The phone with the bad display also seems to have a better keyboard. Out of curiousity - does anyone know how much LG charges for out-of-warranty repairs?
  • Anonymous Mar 18, 2014
    the charging port
  • 21 Answers
You can't repair the charging port because those wires a litterally sautered into the computer board. Potentially you could take the motherboard out of the inside of the cracked screen phone and put it into the charger port phone. Make sure you use the sticker from under the battery on the cracked screen phone and you'll have to get your service changed to that ESN. good luck.
Posted on Jul 23, 2009
  • sprintrepair Jul 23, 2009
    don't know about LG repairs.
    If you have a screwdriver small enough, it's actually a phillips head. There are 6 screws you take out (phone is face down). Two at top, two at bottom, two in the middle. Pull back the sticker, you will use a small flat screwdriver or probe to crack the case back off the front half of the phone - be careful. There are two screws in the computer board. You will lift the computer board out, disconnect the cable from the front half carefully. Then, put it all in the new one. Make sure to plug that cable in firmly or the phone won't come back on. You'll need to switch your service to the broken screen sticker numbers :-)
Charge htc evo 4g lte with broken charging port or how to fix charging port
unless you can open the phone and have soldering skills, take it to a local repair shop to replace
Mar 07, 2014 | Cell Phones
My treo pro wont charge the battery. I have purchased a new battery but the problem persists. I connect the phone to its craddle and tha charging indicator turns on; however, the battery remains at...
Either the charger port on the phone is faulty or the charger itself. Try a different charger if you can and if this works, the dock is faulty, if it doesn't then its the phone. Pretty simple repair and most Treo repair centres will be able to do it.
Feb 03, 2011 | Palm Treo Pro Smartphone
My blackberry bold wont charge no light comes on just completely dead could it be a faulty battery
Does the red light come one when you plug it into a charger? if not, and your charger works on other phones, than you probably have a broken usb port. (check if it is loose). You're gonna have to disassemble the phone and repair the USB port : Blackberry Repair Guide.
Jun 29, 2010 | RIM BlackBerry Pearl 8100
Broken usb charger port on a nokia n86. has anyone else had this problem? The charger port just floats around in the space that its supposed to be fixed and the phone wont charge.
Go to nokia center. I broke my USB port too. I told the staff at nokia care and they agreed to fix it since my phone is still in warranty. I told them i accidentaly broki it and they said they will log it as factory defect. Nice :) I got it back now and they cahnged the entire board.
Dec 20, 2009 | LG Rumor LX260 Cellular Phone
LG RUMOR SCREEN STAY ON FOR 2 SECONDS
Check out this link below to download a PDF data sheet and quick start guide, also live chat support, and more for your phone. Just copy and paste into your browser.
http://www.lge.com/us/mobile-phones/LG-LX260-Lime-Green.jsp
This link below is a complete manual for your phone.
http://www.sprint.com/cdma/assets/pdfs/phone_guides/lg/rumor_lg_ug.pdf
Page 46 in your manual:
Changing the BacklightTime Length
Select how long the display screen and keypad remain backlit
after any keypress is made.
1. Press Menu > Settings/Tools > Settings > Display >
Main Screen > Backlight.
2. Select a time setting and press .
Note Long backlight settings reduce the battery’s talk and standby
times.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 15, 2009 | LG Rumor LX260 Cellular Phone
Charging problem
If it is not charging because the charging port is broken, you should go onto Ebay and buy a three dollar universal phone charger. It charges the battery outside of the phone, so a broken port can be ignored. Also, buy another battery so that you can rotate them out every 12 hours. This is the cheapest solution possible, costing under ten dollars to fix completely.
Oct 07, 2009 | Motorola Mobility L6 Cellular Phone
Won't Charge! :-(
Hi. these situations are mostly caused by a bent or broken copper prong that is located within the input charger port that is inside the phone housing.
When you insert the charge cord into the input port, there are copper prongs that will have to connect to each other and , this contact point will transfer the necessary current to the cell for a proper charge.
If the prongs are damage in any way due to broken copper or, bent copper prongs, this will prevent the necessary current from flowing to the cell.
Most remedies are crude like using a tooth pick or paper clip to straighten out the prongs inside the port. these methods do more harm than good and i recommend sending this phone in for a input port transplant. the manufacture or local repair depot is the best repair solution for this situation.
There is one thing that i would do before sending it to the repair depot. try using a completely different battery cell. if you purchase a new battery and the charger continues to not charge, this will confirm the input port failure.
Please rate and god bless:)
Apr 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
AudioVox CDM 8910 Charger Port Broken
hi plz dont try to do it yourself == go to a local phone repair store and in your presence tell the technician to do it == this will not charge you much and the rick factor will be nill Good luck
Apr 27, 2007 | Audiovox CDM8910WW
LG Rumor LX260 Cellular Phone Logo
340 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
